not signal, suspect ceramic IC chiped
I have a phone my co-worker that was working on and he screwed something up. i suspect this to be the issue?
phone cant get a signal. phone using CDMA network.
Es esta una buena pregunta?
qpunk, that is reference designator U1001_RF and it is a FPF1039 − Low On-Resistance, Slew-Rate-Controlled Load Switch. The datasheet for that is available right here. It is part of the Baseband PMU. Hope this helps, good luck.
Fue útil esta respuesta?
Thank you vary much oldturkey your the best!
you are welcome, and thank you for accepting my answer.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 504
