Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2956 Ver todo
Why aren't my side sound buttons working?
The silence button is not on, my change with buttons tab is set to on. Also, I can hear incoming calls and talk to people on speaker phone and regular volume. However, I can't hear any music, videos, etc. even when I go to change the volume on the now playing screen in "Music" the slide tab won't even show up. When I press the side buttons sometimes, the ringer volume shows up and the small squares showing the volume don't pop up. What should I do? I've only had my iPhone for 3 1/4 months.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Ciaran Change the dock connector as this has the mic attached to it
And Rachel changing the dock will also fix your problems also
Fue útil esta respuesta?
Calificación 1
It sounds like your phone thinks it's connected to a sound dock. Possibly some corrosion has built up on the bottom pins in the dock connector. You can get some Isopropyl Alcohol 91% and try to clean it out with a tooth brush. Be gentle as the pins can easily be damaged. Give that a try as it might be the solution you need.
Calificación 0
When im talking to someone on the phone i can hear them perfect but they cant hear me at all, if i put the caller on loud speaker they can hear me but not off loud speaker . Can someone please tell me how to fix this?
Calificación 0
Añadir tu respuesta
Rachel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 3,448
