Saltar al contenido principal
The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
Preguntas 42 Ver todo
Lost power won't power up
I accidentally plugged a phone charger in one of the other ports. When I did screen went black. No it's not powering up. The battery indicator led lights white then turns green. But will not turn on at all. I hope it can be fixed.
Thank you
Lee
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
3 Respuestas
Try to reset the device? vol up + power.
If it does not work you might need to open the device up and see whats damaged.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thank you I tried the volume up and power button. No go.
- de
Thanks it worked on mine.
Puntuación 0
Thanks so much! Worked on mine as well.
Puntuación 0
Añadir tu respuesta
Lee estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 677
