Black screen after replacement
hey i was replacing me screen. now the lcd wont turn on but the phone is powered on. it's vibrating when i mute the iphone. what to do?
Es esta una buena pregunta?
When you say you replaced the screen. Did you replace just the glass? Or the entire screen assembly?
Also, where did you get the part? I've seen many cheap screens for iPhones from Hong Kong and China have bad LCD's right out the gate.
If you were trying to replace the glass only and attempted to separate the glass and LCD, then I would have to say the LCD was damaged in that process and that's why its no longer kicking on.
If you did buy the entire screen assembly with the LCD and Digitizer already fused together, then its possible the connection was not properly made. I would make sure the LCD connector is plugged in snug. Also, try and hard reset. (Hold power and home button for 10 seconds until phone restarts). If the phone was kicked on by mistake during the repair, then it may just need a good hard reset to fire up that new LCD.
If none of that works then its possible the LCD in the new part is bad. Contact the supplier that you ordered it from and see what they can do to replace the part for you.
Hope this helps!
Fue útil esta respuesta?
thank you hard reboot helped :)
I've had the same problem on two occasions. After replacing the screen the LCD has completely stopped working.
I have tried hard reset, different screens, software restore, disconnecting the battery all without success.
Any ideas??
Krid what could be wrong with the logic board for the screen not to turn on
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,019
