Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 3045 Ver todo
Pregunta Cerrada
iPhone 4S - No Service but carriers show?
Guys,
I've had problems fixing a 4S a friend gave me. I'd love to get it back to working order as cosmetically it is brand new, and everything except the signal works great.
It was dropped, I repaired the screen, camera and swapped the battery. Its was locked to (3) UK, I got it unlocked with a code.
It is now just stuck on 'searching' or 'no service'.
When I goto Settings > Carrier, I can press 'manual' and the services show, which makes me think that there isn't any major problem. However, even if I select the network, it still shows no service.
If somebody can help me out it'd be much appreciated, be happy to throw them some paypal their way.
EDIT - Ive just taken it into town and it came up with FULL SIGNAL for around 2 mins, then went back to no signal. Does anybody know what the problem is?
Many Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Comentarios:
Ive tried setting the date and time. They are set correctly, set to automatic. Is that right? Or is there a trick to it? Any other ideas people?
- de
Agregar un comentario
7 Respuestas
Respuesta Más Útil
make sure date and time and set corretly
Fue útil esta respuesta?
Puntuación 1
Comentarios:
Thanks, but the date trick did not work on this one. I have added an EDIT into my post on what happened today. Any other ideas? Thanks
- de
Just had the same problem on my 4s now for the last week. Just reset network settings and problem solved ... Mobile signal returned. I had to set up my wifi password again but otherwise all good.
Settings>General>Reset>Reset Network Settings
Puntuación 1
got the same problem with my 4s.
just "searching" or "no Service"
Carriers are shown when switched to manual... so i guess it finds the network but couldn´t or won´t log in... don´t know.
are there any new suggestions for this problem?
it runs with ios7
Puntuación 0
Be nice if we could get some answer that would help us mine doing the same thingy an it brand new pretty much !
Puntuación 0
Weird stuff guys. Usually I get the opposite problem, with customers phones
Puntuación 0
Does anybody has the answer? i'm having the same problem manual carrier selection shows list of available carriers i tick my simcard carrier done but no service and not even a single bar of signal, soon it shows me my network lost..help please
Puntuación 0
have you tried changing the speaker at the bottom as the antenna is connected to it , or make sure the cable is seated properly could possible be that ,
hope it helps
Puntuación 0
Comentarios:
not yet but i'll try it now, thank you i will keep you updated
- de
i have the same problem on iphone 5s im just going to changed the antenna now , ive searched this so many times , and no soloution
- de
Have you guys checked IMEI number to see if it is blocked?
- de
i have checked the cellular antenna cable is seated properly, imei is clean also, i cannot even dial emergency number, restore normal dfu and recovery still i cannot get even one signal
- de
ive done the exact same changed antenna , check imei , i get ee signal , 3g/4g but cant dial out etc , this a joke , i have a apple brick
- de
Mostrar 3 comentarios más
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 4,479
