Saltar al contenido principal
Intel Core i5 de doble núcleo a 1,8 GHz (Turbo Boost de hasta 2,8 GHz) con 3 MB de caché L3 compartida
Preguntas 368 Ver todo
Water spill - battery is not charging but everything else works fine
Hi everyone,
Hope someone here can help with my situation as described below and thanks in advance.
I spilled almost a cup of water on my macbook air last Saturday. I tried to turn it off immediately but it wouldn't turn off and the fan was on high speed for about 5 mins until it turned itself off.
I put it in a rice bag for 2 days and then put it in a room with heater on for a few more days since we haven't had any sunlight this week (really bad timing). I just turned it on today. Everything - display, fan, temperature, keybaord backlit, speakers - is working perfectly fine except the battery. The light on the charger is orange but the battery menu says:
Condition: Replace Now
Battery is Not Charging
Power Source: Power Adapter
I also ran Coconut battery app and it read:
+ Battery Charge
Current charge: 0 mAh
Max charge: 0 mAh
-9.223392e+ 18% (in the progress bar)
+ Battery capacity
Current capacity: 0 mAh
Design capacity: 6700 mAh
0% (in the progress bar)
I'm wondering if anyone knows if it's the problem with the battery itself, the logic board or something else. I don't want to buy a replacement battery only to find it is something completely different.
Any help would be much appreciated :)
Thanks,
Phalkun
Es esta una buena pregunta?
Puntuación 2
3 comentarios
Hi Phalkun,
I have the same problem. I am just wondering what happened after you opened and cleaned up your computer? Please let me know.
- de
Did you replace the battery yourself? Or had it replaced by an Apple tech? :)
- de
I bought tools and a battery from ifixit and replaced the battery by myself. it's really easy. Just follow the instruction on the site.
- de
Agregar un comentario
5 Respuestas
Solución Elegida
I meant to update this. My computer is working fine now after replacing the battery :)
Fue útil esta respuesta?
Puntuación 3
I know of no "shade tree mechanics" test for battery, other than placing it in a similar unit and see how it acts... which could damage the other unit. Compare the price of a new battery, or a new DC-IO board. to having Apple or someone else diagnose your problem - Consider the economics of using the money required to purchase a replacement IO board, or battery,- selling the laptop as is, or parting it out, and buying a replacement laptop .
Only you know what your budget and time restraints allow.
Good Luck,
If this Answer is helpful please remember to return and mark it Accepted.
Puntuación 1
1 comentario:
Hi @machead3, thanks a lot of your response. We don't have an apple shop here in new zealand tho we have a few authorized shops for Apple. I'm quite reluctant to go there since, from what I heard, they tend to replace the logic boards, which I can't afford.
I'm still waiting for screw drivers from ifixit. I think I'll open it up and dry it properly before going with other options. I just hope it's not a logic problem.
Again, thanks a lot :)
- de
I have the same issue. You can change your battery and try again. You can replace the battery if it is the battery issue.
Puntuación 1
Hi
did you find a solution to your battery problem ?
I have your same problem!
Alberto
Puntuación 0
any way to diagnose whether this is a battery problem or logic board problem?
Puntuación 0
2 comentarios:
An initial diagnostic is to measure pin voltages at the connector on the logic board with a multimeter. If there is no output or it's incorrect, logic board is involved for sure, making therefore useless to purchase a battery. This doesn't exclude of course the battery could be faulty too.
- de
Thanks, this is pretty helpful!
- de
Añadir tu respuesta
phalkunz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 29
Todo El Tiempo: 6,692
