Saltar al contenido principal
¡Todo lo que necesitas para reparar tu iPhone tú mismo! IFixit tiene guías de reparación e información de desmontaje gratuitas para cada iPhone, como también los mejores recambios y herramientas en la galaxia.
Preguntas 34497 Ver todo
What component determines The Network / unlocked?
What actual part of the iphone holds the information if its locked / unlocked and even imei number???
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
It depends on which iPhone you're talking about. Up until the iPhone 4, all models were GSM only, which meant that it had to be a carrier with a SIM card (AT&T and T-Mobile, here in the states). Starting with the iPhone 4, however, the ICs on the communications board determine whether the phone is CDMA or GSM.
Locked or unlocked is another beast altogether. If you have a phone that is locked to a carrier, you may not use it on another one. For instance, a locked AT&T iPhone will not work with a T-Mobile SIM card. Similarly, you cannot activate a Verizon-locked iPhone on your Sprint account, even though they're both CDMA. Phones are locked so that a carrier can keep your business over the course of a 2-year contact, which is why they're able to sell you a brand new iPhone for $200 instead of $600.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
Hey thanks for the asnwer! actually what i was referring to was if you have a locked phone and unlocked phone what component would you have to switch in order to make make the other locked and the other unlocked... If you get me???
thanks
- de
Joe, you are looking for a "physical part" where the information is stored?
- de
Yes a physical part any ideas?
- de
Añadir tu respuesta
Joe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 368
