Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2193 Ver todo
Where to buy a Logic/Motherboard Replacement
Hello all,
Can anyone help me with this, I recently replaced a battery on my 4S the battery went in fine (something I've changed plenty of times before).
This time however when turning it all back on the phone never found signal again, I tried everything I could think of and checked all the connections which seemed fine but still no luck. I took it to a local repair shop and they tried a few things and said somehow I'd blown a chip on the motherboard and it was basically knackered!
They tried something called re boiling the chip and this didn't work and told me nothing else could be done.
Is it possible to get a full replacement logic/motherboard and if so where and are they expensive??
Also has anyone else had this issue??
Thanks in advance
Si
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
6 Respuestas
Solución Elegida
Si, PowerbookMedic has some used ones as well as ebay.com. These are used and the cheapest one is $250. New ones are available from places like alibaba.com Cost for those is $360 and up. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
I would go with PowerbookMedic, they have a good reputation where as you might end up not getting what you expected from an e-bay seller.
- de
In the market, you just buy the USED one. If you want, please let me know.
Puntuación 2
3 comentarios:
any one help me where i purchase motherboard fo i phone 5s
- de
hi , i need a used motherboard for my iphone 6 64 gb variant.
Please send your contact no on nbsteam7@gmail.com.
i will surely get back to you.
- de
Any wana intersted for buying all iphones used mother bord ,logic bord. Please contect my email
sharmajimaharaj1975@gmail.com
- de
Did u get it changed? If so, help me Im having the same problem
Puntuación 0
Yes, I have bought the Motherboard Replacement and new phone's on that site. Really cheap and high quality for the step price. All the |phones accessories| and find it values more than you paid.Freeshipping at Wholesale Price. Great one.
Puntuación 0
1 comentario:
in which site?
- de
It sounds like the unit was still powered on when you replaced the battery. When you pull the battery connector, (while it's still hot) it causes the first capacitor and IC in line to blow out. Replace the cap and IC. AFAIK.
Puntuación 0
my motherboad is dead
Puntuación 0
Añadir tu respuesta
Si estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 26,179
