Model No. A1367 / 8, 16, 32, or 64 GB capacity
Preguntas 1289 Ver todo
Why won't my iPod charge?
The cable isn't the problem. It works fine on other apple products, but on my ipod touch 4th generation, i think my ipod doesn't have connection to the charger. Maybe there's something wrong with the input in my ipod??
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 6
Comentarios:
Is your iPod still coming on at all? Does it get recognized by iTunes? Did anything happen to it before this became an issue?
por
my I pod is not recognizing my charging cable
por
I have the same thing. It won't be recognized by iTunes or show that its charging, but when I plug it in and leave it for and hour it will charge. It is really starting to annoy me and my local apple store can't fix it. Please help!!!
por
My iPod doesn't seem to recognize the charger but the charger works for other devices plus the iPod works fine otherwise.
por
hello my ipod isn't charging either and this time it is a 6g instead of a 4g so yeah
por
Mostrar 1 comentario más
Agregar un comentario
8 Respuestas
Solución Elegida
Katerina, check the dock connector (the part on the bottom where you plug your cable in) make sure that it is clean, no dust in there, that the pins are not broken, bend or corroded. Clean it with some isopropyl alcohol and a few puffs of compressed air. after that, try to charge it from an AC adapter, not a computer. If none of that works, you might consider changing the battery. Follow this guide to get it accomplished. Hope this helps, good luck.
Fue útil esta respuesta?
Calificación 1
Comentarios:
well some of my metal bars are broken ans bent but its been like that for about a year and its been fine tell now.
por
but i have a 6g not a 4g
por
Respuesta Más Útil
I have this problem to.
It is really really really annoying!!!:(
It just stays on the charging page with a red battery sign!!!
I've had the bottom removed and replaced already but it hasn't changed I can't reset it because I can't even get to my settings!!!!:( HELP!!!!!!!!!!!!!
Calificación 2
Same here I had that problem. My laptop wasn't recognize my Itouch. So what I did is I connect to newer windows 8 laptop and press the bottom below then I restored my Itouch to factory setting. After that I saw the recharge sign again. This might help.
Calificación 1
This is not an answer..... My ipod is not charging either,I don't know what has happened to it. So this all started about a year ago at the beach..my ipod went dead so of course i plugged it in and it said it was charging and hour later I came back and it was not charged! I put it in my bag and left it there until the end of my beach trip and then when I got home it was still doing the same thing....Then here recently I got it to charge,I was so happy,but now all of a sudden,IT WONT CHARGE AGAIN!!i'm really getting frustrated with it now...PLEASE HELP ME!!!!! I appreciate any help I can get... Thanks!
Calificación 1
Comentarios:
That's the same thing that happened to me.My iPod touch is not responding to the charger, it won't charge it just keeps saying 'this accessory may not be supported' and it driving me crazy PLEASE HELP!!!
por
same that happened to me to
por
Mine does that too and I have no idea on how to fix it!!!
Calificación 0
zxdcfvgbh7ytgfcxedrfghj# 123456# * Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)''omggggggggggggggglibold te== xcvbgfdsjkkjhgfdsxcvbnmn ==xt''
Calificación 0
qwertyuiopasdfghjkl;zxcvbnm,123456789zaqxswcdevfrbgtnhymju,ki.lo/;p/..;,llpmkonijuhbgvttfcdxszwawazesxrdctfvygbuhnijmok,p.[;q
Calificación 0
Comentarios:
why would you answer that?
por
Make sure your Bluetooth is off! I was stumped for a while but then noticed it was on and as soon as I turned it off my iPod started charging again!
Calificación 0
Añadir tu respuesta
Katerina estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 49
Últimos 30 Días: 200
Todo El Tiempo: 34,285
