Samsung Galaxy Ace S5830 screen replacement
Replaced screen on Galaxy Ace S5830 and all looks normal except it doesn't respond to tactile commands. Can anyone help please ?
Es esta una buena pregunta?
Lanzado en febrero de 2011, el Samsung Galaxy Ace es un teléfono inteligente fabricado por Samsung que cuenta con un procesador Qualcomm MSM7227 de 800 MHz con la GPU Adreno 200.
malcolm watson, double check your work. In particular, check the connector on the back of the bracket. Make sure that it is properly seated and that the cable is not tore.
Hope this helps, good luck.
my touch respond only sometimes. The connector indicated by oldturkey03 in my phone is ok but nothing...
Rep: 1
Mi telefono no reconose mi chip y no me deja descargar cosas me sale memoriia insuficiente y el chip no figura la red o señal
Rep: 1
The digitizer doesnt work! Please check spec S5830/S5830i (this no work for s5830) but is twin.
Check the digitizer chip is synaptics.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 5,201
