Saltar al contenido principal
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
Preguntas 698 Ver todo
Why does it blow white smoke out of exhaust?
14.5 Briggs and Stratton Murray riding mower was in storage. Model number: 287707
Turned it on, stepped on the gas and would stay on for only a few seconds. White smoke would then blow out from the exhaust. The next day i turned it on and would turn off when i stepped on the gas. Checked the air filter and had fuel and oil mixed. Filter was wet. What can i do?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Kits de reparación de iPhone X
¿Garantía vencida? No te preocupes, tenemos la solución.
Comprar Ahora
Comprar Ahora
1 Respuesta
Solución Elegida
Juan Hernandez, depending on how long it has been in storage, You could easily have bad/old fuel. The reason for the white smoke is most likely the excessive burning of oil, mixed with water from humidity. The "turn off when i stepped on the gas" most likely caused by a bad mixture. Change the fuel, replace the fuel filter. Clean the carb and fuel bowl and replace your spark plug, then re-evaluate.
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
Juan Hernandez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 9
Últimos 30 Días: 86
Todo El Tiempo: 4,762
