Saltar al contenido principal
Modelo A1181: procesador Core 2 Duo de 1.83, 2, 2.1, 2.13, 2.16, 2.2 o 2.4 GHz
Preguntas 1203 Ver todo
Installing Mac osx on windows 7
I have a white apple mac book A1181 model but i experienced some problem with it (lost my password) so i clean formatted my mac book with windows 7 by changing its volume to NTFS from GPT partition and installed windows 7 successfully while i could not find any way to install its device drivers, i.e its sound does not comes, but i can hear its start up sound when i power on my mac book, now i think of installing mac os x 10.5.8 back on it, will i be able to install Macintosh back after converting my partition to NTFS to GPT again and will i able to install device drivers for my a1181?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
If your idea is to have a dual OS setup with NTFS as the underlying format the answer is no.
You will need to reformat the HD back to the original GPT (GUID Partition table) partition with a Journaled HFS+ formatted volume for the Mac OS-X to sit on.
Using your OS install CD/DVD the system came with or a purchased Snow Leopard DVD you should be able to rebuild the HD back for OS-X. If you want to install Mountain Lion you will need to get back to Snow Leopard first then you can install it on top.
Once you get to the desired Mac OS-X you want you can then setup Boot Camp to setup a partition of Windows to run within. If you have that need.
As to protection - I would strongly recommend setting up two or more users on your system. The first user will be your Admin account (use any name you desire for this & password) This account will manage the Apps and general maintenance of your system. The next account is your every day user account (again pick a name & password your like here as well but different from the admin account) and you don't give it Admin privileges. To protect the data of this account you can also use file vault to protect this users files. In any case the Admin user still can't access the files of this user directly.
Doing the setup like this offers two distinct advantages: You can use the Admin account to delete the other account(s) if they get infected without having to loose everything and this users data can be doubly protected using file vault without using the full HD file fault protection (you can limit the vault to just a single or group of sub folders under the users account as well)
And of course - Don't forget your passwords!!!
Fue útil esta respuesta?
Puntuación 2
Hindi: Bhai window 7 dalte waqt mac format ho gaya window 7 chal rahi hai par mac nahi. ab lap koi commend hi nahi le raha hai bar bar window 7 open ho jati hai kya karu
MacBook A1181 hai bhai mere pass
English: Bhai, Windows 7 can't be used on a Mac formatted drive. I do not want to comment as I don't know what to do.
I have a MacBook A1181.
Puntuación 0
1 comentario:
Hindi: maik vibhinn prakaaron mein emes vindoj chala sakate hain. lekin aapako ise sahee dhang se instol karana hoga. sabase aasaan tareeka ek aabhaasee masheen (veeem) mein maik phail sistam ke bheetar hai jo epals bootakaip seva ya veeemaveyar jaisee teesaree paartee upayogita ka upayog karate hain.
haan, aap kisee bhee vindoz peesee kee tarah maik ka upayog bhee kar sakate hain. lekin aapako sthaapit karane ke lie aavashyak draivaron kee aavashyakata hai aur eppal keval unhen bootchamp mein pradaan karata hai ya un vindoz ke un sanskaranon mein se kisee ek ka upayog karen, jo ise apane bheetar hai. yah aisa kuchh nahin hai jo main sujhaata hoon!
phail sistam ko gpch (guid vibhaajan taalika) ko bootchamp ya vm warai ke saath rakhana chaahie kyonki ve apane mool sthaan mein vindoj ko pakadane ke lie ek vishesh foldar banaate hain.
मैक विभिन्न प्रकारों में एमएस विंडोज चला सकते हैं। लेकिन आपको इसे सही ढंग से इंस्टॉल करना होगा। सबसे आसान तरीका एक आभासी मशीन (वीएम) में मैक फाइल सिस्टम के भीतर है जो एपल्स 'बूटकैप सेवा या वीएमवेयर जैसी तीसरी पार्टी उपयोगिता का उपयोग करते हैं।
हां, आप किसी भी विंडोज़ पीसी की तरह मैक का उपयोग भी कर सकते हैं। लेकिन आपको स्थापित करने के लिए आवश्यक ड्राइवरों की आवश्यकता है और एप्पल केवल उन्हें BootCamp में प्रदान करता है या उन विंडोज़ के उन संस्करणों में से किसी एक का उपयोग करें, जो इसे अपने भीतर है। यह ऐसा कुछ नहीं है जो मैं सुझाता हूं!
फाइल सिस्टम को GPC (GUID विभाजन तालिका) को BootCamp या VM Ware के साथ रखना चाहिए क्योंकि वे अपने मूल स्थान में विंडोज को पकड़ने के लिए एक विशेष फ़ोल्डर बनाते हैं।
English: Macs can run MS Windows in a couple of different ways. But you need to correctly install it. The easiest way is within the Mac files system in a virtual Machine (VM) using either Apples' BootCamp service or a third party utility like VMWare.
Yes, you can also use a Mac just like any Windows PC. But you need to have the needed drivers to install and Apple only offers them within BootCamp or use one of the versions of Windows that have them within it. This is not something I recommend!
The file system needs to be GPT (GUID Partition Table) with BootCamp or VM Ware as they create a special folder to hold Windows in its native space.
- de
Añadir tu respuesta
Ankush Jain estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,823
