Broken antenna connections connected to the top of the iPhone 5 case
I noticed that I snapped the two antenna connections pictured below.
Is there a replacement part for this ?
Please advise.
Thank you,
They are screwed onto the case. In this image you can see where the tech is removing the screws: http://guide-images.ifixit.net/igi/ipuKf... In this image you can see the logic board being removed and the two L shaped connectors on the top left of the logic board are antennas: http://guide-images.ifixit.net/igi/JhpPx...
Es esta una buena pregunta?
3 comentarios
My apologies try these links http://i295.photobucket.com/albums/mm151... http://i295.photobucket.com/albums/mm151...
I broke them removing the motherboard
- de Brad
I am having the same problem, Brad how did you resolve?
- de buffoonist
Can I ask? What happened if the L shaped connectors is broken?
it can be worked properly?
- de jhoy manabat
