Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Preguntas 1488 Ver todo
Display not straight when closed
Hello, I bought this machine several months ago off ebay. Ever since I got it, the display has been crooked on the left hand side when it closes. However, it still sleeps and functions perfectly.
Recently, the LCD panel cracked. I have ordered a new one, and since I have to open up the display assembly, I fugre I might as well fix that problem while I am there. Does anyone know if this is a problem specific to a loose hinge, or would it be how the assembly mounts in the case? I will of course tighten everything when I get in there, just curious if there is something specific I need to do or look out for.
Thanks.
¡Contestado! View the answer I have this problem too
Puntuación 0
Añadir un comentario
Kits de Reparación de Android
Estás a un kit de tu nueva pantalla o batería.
Comprar Ahora
Comprar Ahora
1 Respuesta
Solución elegida
I would think the unit was dropped and the hinge either torn inside or bent. Check both hinges where they meet the lower case... they both could be slightly torqued.
Puntuación 2
Comentarios:
Thanks! Not only did I get the display panel replaced, but I noticed the left hinge was bent upward. I took a pair of pliers to it, and then just started bending it back with my hand. I used a bubble level app on my iphone, it was 6 degrees out of alignment! but I got it back to 0, and the case now closes perfectly. It must have been dropped in it's past life. Oh well, I got the chipping top case replaced by apple for free under the repair extension, and got a new keyboard and trackpad out of it.
Now I just need to wait for the key hinges to arrive for the 2 that got damaged, pop on the key caps, and it will be as good as new. Can't seem to find a guide for it here on ifixit, but i'm sure I will find something if I google it.
by
Add your answer
Leo LeBron will be eternally grateful.
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
Global: 89
