Saltar al contenido principal
Repair guides and support for cars and trucks by Dodge.
Preguntas 534 Ver todo
check gauges light on
after replacing timing chain cover the check gauges light came on. Had the alternator check but it passed. What else should I check. Truck is a 99 dodge durango
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Baterías para ordenadores portátiles
Un pequeño arreglo para un gran resultado.
Comprar Ahora
Comprar Ahora
2 Respuestas
Solución Elegida
I would take it to a place that can do the OBD scanning. Places like Autozone do it for free, it will give you at least an idea of what might be going on.
Fue útil esta respuesta?
Calificación 1
A 99 Durango, you have an unlucky 7 engine. All Chrysler 2.7, 3.7 and 4.7 engines have a serious problem with sluge. Most likely when removing the cover you disturbed the build up. What happens is the sluge has now clogged the pick-up screen for the oil pump. That's the most likely cause of your problem. Proceed cautiously. If your up for battle that may never be won you can remove the oil pan and clean the screen.
Sorry, but most likely true.
Kevin
Calificación 1
Añadir tu respuesta
Gabriel Lopez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 123
