car dies when driving then you can start then goes
98 honda accord 4 cly vtek
Es esta una buena pregunta?
There is a tsb for that problem. The electric terminals on the ignition switch get burned and this causes resistance. Call your dealer and ask if yours falls under the recall. If it does they will fix for free. If they already did it once they will not do it again for free.
Kevin
Fue útil esta respuesta?
See if you can get an auto parts store to interpret/read trouble codes. There are so many things this could be from dirt in the fuel tank/line/filter to a collapsing vacuum hose even a cracked/bad head.
If you were to work through them I'd go from easiest to access/cheapest to replace if the codes are no help.
If this Answer is helpful please remember to return and mark it Accepted.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 358
