Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2.3, 2.6 o 2.7 GHz (Turbo Boost hasta 3,7 GHz) con 6 MB de caché L3 compartida.
Preguntas 559 Ver todo
Monitor upper metallic case is slightly deformed, how to fix?
I accidentally dropped my mac, therefore monitor upper case was slightly bent.
It had caused the yellowish area on the screen
When I bend temporarily with my hand back, the yellowish area in the LCD restores to normal. I would like to know how could I get the case back to normal. Please, help! ^^
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
Disassembly to the point where you can remove the screen and work on the metal corner of the case with wood/plastic tools, mallets to try to reshape or reduce the amount of deformation is one option... the other solution is to replace the damaged part completely.
If this answer is acceptable please remember to return and mark it.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thank you for your answer. What other tools could you recommend?
Can't find a part for upper case. Thank you.
- de
Leather wrapped mallet or tools. You don't want to scratch or further dent the metal so that precludes using anything really hard, or harder than the soft aluminum.
- de
Añadir tu respuesta
R B estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 525
