Why is the backlight not working?
Hi
I just replaced the lcd of my macbook and now the backlight does not work. when I turn on the laptop, the lcd works but the backlight does not turn on. I tested with a couple of screens but no success.
Is the problem with the backlight LED, or fuse or logic board, is there any solution?
Model: Macbook air, 11 inches model A1370, 2011.
Any help would be highly appreciated
Es esta una buena pregunta?
What are the last three of your serial number? that number will allow us to identify your computer and your motherboard a bit better.
- de oldturkey03
When replacing an LCD u need to be really carefull and me personally don't recommend doing it yours self.
maybe u forgot one of the cables when closing it?
- de Rico
Hi
the last three letter of serial number are: JYC
all the cables are connected, the thing is that at the beginning i connected the backlight cable inversely, that might have missed up something...
- de Navid km
Navid km, it does appear as if your MBA has a backlight fuse. "The fuse is on the same side as the LCD connector (upper left, looking at the logic board with the botom cover removed). It is near a small 6-pin chip (WLED driver?) and the fuse itself is very tiny with a white dot (or "P"" in the center).
- de oldturkey03
Hi thanks for the nice replies,
I have to open the case and check the fuse on the motherboard, Can you please let me know where the WLED on the motherboard is and how to test it?
Navid
- de Navid km
Mostrar 7 comentarios más
