How do I know if the management ic is damaged?
hi, my iPhone 4 is dead only turn on when i connect the wall charger as soon i disconnect it the phone turns off i want to know if is the management ic or the real problem, i also changed the battery and clean the motherboard with alcohol....i don't know what to do any more pls help.
Es esta una buena pregunta?
5 comentarios
what is the voltage on your battery connector with the phone being plugged in. Measure the left and right outside contacts.
- de oldturkey03
Just wondering, is this linked to my issue as well? Here: iPhone 4 After Repair Stuck on Apple Logo & Cannot Restore
It does the same thing when I unplug the iphone 4, it just immediately dies.
- de asdfADRiAN
Very possible you won't know unless you test with a multimeter or a working battery. I highly recommend taking a closer look at the board and checking if you damaged something. Software restore is not going to fix the issue. .
As for the microphone problem I can almost guarantee that the problem is the audio IC (located on the top left corner of the logic board- you have to take the logic board out to see it) You can resolve the issue by removing a part of the heat shield metal and putting something like a cushion (I used folded paper+tape) to put more pressure on the IC therefore completing the connection.
- de Alfy
i have a problem with my iphoen 4s
it shows error 50 in restoring iphone
i think it is power management ic problem
plz give me a solution
- de Aashak meeran
How to check if the ic is problem with multimeter?
- de Animushi
