Saltar al contenido principal
General Motors' GMT400 platform.
Preguntas 83 Ver todo
Pregunta Cerrada
Started shifting hard, and stuck in 1st. Now won't start?
I have a 1995 Chevy Tahoe, 4WD/350 (non-Vortec). After washing it, the transmission started shifting hard, and then stuck in 1st or 2nd; when killed it wouldnt start unless i poured a little gas in the throttle body, and it will start and run till i kill it. i have changed the fuel filter
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Eric,
There is not a lot of information on the GM Service Information website for your vehicle due to its age. There is a service bulletin #67-71-53B - No Upshift/2nd Gear Only After Cold Start-Intermittent DTC 87-High Ratio Error. The fix for this is to replace the PCM EPROM.
I would suggest that you take this to a trained technician for further diagnosis. You have a couple problems. First you have a no start problem. There could be many things wrong to cause this; from a bad fuel pump to a faulty PCM, to a MAF sensor problem, to a fuel pressure regulator problem, to a TPS problem or even a CKP sensor problem. Any of these problems will cause a no start. Try pushing the accelerator to the floor to start the vehicle. By doing this you cause the PCM to ignore certain inputs and attempt a start.
Secondly you have a drive line problem. It could be anything; from a restricted transmission filter, to a TCC solenoid stuck on, a locked torque converter clutch, a faulty transmission valve body, a transfer case that is stuck in 4X4 low, a transfer case that is locked up, ect.
There might be a wire that is corroded somewhere that could cause issues. Or you may need a new PROM in the PCM. These are all common problems that GM's around yout year have had.
Good luck,
- B.
Fue útil esta respuesta?
Puntuación 1
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 748
