Saltar al contenido principal
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
Preguntas 21 Ver todo
Pregunta Cerrada
Can you cut one set of wires?
My floor lamp has five arms resulting in 10 wires, can I cut one set of wires and cap (one arm has faulty base)?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Yes but you must cap/insulate each end of the pair you cut.
If this Answer is helpful please remember to return and mark it Accepted.
Fue útil esta respuesta?
Puntuación 2
I can confirm previous answer.Its not necessary but if possible also is good to check for grounding,or short circuit..
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 253
