Wont power up after screen repair?
Okay, first off, I ordered the digitizer for the iPad. Once it got here, I began dissasembly. After I had finished and was ready to install the new digtizer, I realized that The connectors looked different. After some research, i came to find that you have to desolder the circuit board from the old one and solder it to the new one. I did so. I also soldered on the home button. I was finally relieved to be done with that tedious soldering. I started to assemble, and after I had the digitizer and lcd connectors connected I put the metal plate in, then just sat the lcd and digitizer in the frame so I could test it. There is no sign of power whatsoever. I tried to plug it into a charger. Everything. Please help.
Es esta una buena pregunta?
2 comentarios
High Alex! Gather another 100.000 unsatisfied customers, meet at Cupertino, build a pile of iCrap Minis, pour a gallon of regular unleaded, flic a match and
yell: ' Steve is dead and so will be Apple' ! Make sure that CNN, WKARP, &&& lots of cameras'n'microphones are around! Speak loud and clearly that U are really !@^&&* off with Apple products & Apple behavior!!!! That might help!
Sometimes U have to kick balls in to order to achieve a 'brainreaction'!!
Good Luck!
AlexThe Kraut
- de Alexander deLarge
Alexander deLarge, how is this answer going to help Alex to fix his device?
- de oldturkey03
