Saltar al contenido principal
La Kenmore 90 Series es una lavadora fabricada por Kenmore
Preguntas 266 Ver todo
Has a burnt smell
Motor is on but not spinning and has a burnt smell
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
Have you checked the motor coupler? What have you checked on thus far?
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I'd open it up and see if you can isolate the smell.
Motor Coupling
If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Motor
If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Fue útil esta respuesta?
Puntuación 3
My washer Kenmore 90 series it washes its spins it drains but it smells like a burning smell comes out
Puntuación 0
Añadir tu respuesta
Gregory Herrera estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,777
