Replace Superdrive with 2 hard drives?
Is it possible to replace the superdrive with two 2.5" hard drives? Just want to use duo SSDs to replace cost.
Es esta una buena pregunta?
Ronnie - You only have two SATA ports in this system both are in use (current HD & Optical drive).
So you'll have to decide which device you are going to swap out. You can either take the optical drive out to install a second HD or SSD or take the current HD out and put in a SSD.
There isn't enough room or power or I/O connections to supply a third device.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,571
