Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Modelo A1278 /Procesador 2.4 o 2.66 GHz Core 2 Duo de mediados de 2010
Preguntas 935 Ver todo
hang up glass on MacBook Pro after lcd replacement
Hello to all guys, thank you in advance for the advice.
I wanted to ask you a question, I have to disassemble the lcd of my macbook pro mid 2010, but I have a question, after I removed the glass and replaced the lcd panel I'll have to remove the glue on the inner frame and reattach the glass (the glass is not damaged then reassemble his original) or I can simply plug it in again without any cleaning of adhesive?
Thank you all
Andrea
(from ITALY)
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
1) get a towel or some soft surface
2) get a heat gun or a hair dryer and heat up all the adhesive for about a minute
3) scrape all it off with a plastic pry tool or finger nail (be careful not to #*&! up the paint on the inside)
4) apply new adhesive.
Done hope it helped bro
Fue útil esta respuesta?
Puntuación 0
Comentarios:
Thanks Scott I've been very helpful! I figured the process was so but I have to remove the adhesive from both the glass from the frame inside?
thanks again
- de
Añadir tu respuesta
AndreaBaglione estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 396
