Saltar al contenido principal
Mediados de 2006 / número de modelo A1181 / carcasa negra o blanca / procesador Intel Core Duo de 1,83 o 2,0 GHz.
Preguntas 418 Ver todo
Cracked casing on back of laptop
Hello, I dropped my Macbook and unfortunately have cracked the back of the laptop on the casing (just above where the battery compartment is located. The computer still works but I am worried about dust and moisture getting inside the computer. Do you sell a casing and is this easy to fix or quite complicated?
Thanks,
Dan Griffith
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
I agree, it's a difficult procedure, requiring transplanting pretty much all of the MacBook's components to another bottom casing. Although, it is do-able, and iFixit has a guide, so you can see what you're getting into. The bottom casing can be purchased on eBay and probably iFixit for a fairly reasonable price, however there are a couple different versions, so it's important to make sure you get the Core Duo bottom casing and not the Core 2 Duo casing.
If you decide to live with the casing as-is, perhaps some heavy duty clear plastic tape over the cracks would alleviate the concern about dust and moisture.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
the case is not dust or moisture tight anyway - so not much has changed. I agree with ^ that take the crack and live with it for the time being is the most efficient solution
- de
There doesn't seem to be the part itself for sale but here's the guide for installing it (It's rated "Difficult")
Puntuación 0
Añadir tu respuesta
dan02 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 905
