Saltar al contenido principal
The Motorola DROID 3 is a smartphone by Verizon Wireless running the Android 2.3 operating system by Google.
Preguntas 9 Ver todo
Pregunta Cerrada
Droid can not find service
Phone dropped in water. After 24 hrs. phone powers up but can not get service. Does radio need to be replaced? How would I replace radio? Does it just need to be taken apart and blow forced air into parts.
Help.
Many thanks
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Several things can cause this. If the phone was dropped there may be a connector problem where the antenna flex cable has popped out of the socket I haven't worked on this phone but they are essentially all the same inside.
Check the setting under network and see if you are searching for a roaming network or make sue the settings are set to your network
Fue útil esta respuesta?
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 487
