Saltar al contenido principal
Sony PlayStation 3 Move es un controlador inalámbrico que funciona en el espacio 3D. El Move se combina con una PlayStation Eye Camera para que el juego cobre vida para el jugador. La reparación es sencilla y requiere destornilladores comunes y herramientas de palanca. Número de modelo del controlador de movimiento: CECH-ZCM1U. Número de modelo de cámara ocular: SLEH-0048.
Preguntas 19 Ver todo
Why my Move controller sphere light is not working?
From last 4-5 months I have not used my move controller but before that it working fine. Now 2 day ago when I connected it the sphere light is not on at all all other button are working fine. Please help me to get this correct.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 11
1 comentario
when I try to use my controller the light at the bottom of the unit just keeps blinking very fast.the globe light at the top of the unit does not light up.someone mentioned a reset button where would I find this ?
help.
- de
Agregar un comentario
8 Respuestas
Respuesta Más Útil
Navin, try to use the reset button in the back with a pen or a paper clip. Also, you do want to check on the battery. Make sure that it is holding a charge. Use your multimeter to see if it has a charge. Check the ribbon cable from the light globe for any corrosion and make sure it is properly seated. Use this teardown to get to it. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 3
charge the control using your pc usb port for a few hours then plug it back into the ps3 console then it should be fine. remember it doesn't light up until you start a ps move game!! its not lightning up because the battery's have been 100% drained and take a good wile to kick start the battery pack again.
Update (01/21/24)
These battery’s take a good ten minutes to get life back into them. Instead of using the PlayStation to charge it use the pc to charge it. Once it’s got enough charge to turn on, the tiny red light will start flashing. Remember! the big ball doesn’t light up till you’re in a game! If the little red light doesn’t start flashing after 10 minutes you can try leaving it for Upto an hour. If nothing by an hour thats a good indication the internal battery is goner. You can change the battery your self but need to be a bit tech minded
Puntuación 2
1 comentario:
So how do I fix it?
- de
hi! were you able to fix it?
Puntuación 1
I haven't used my move controller for a long time, a few days ago I decided to play a game the controller wouldn't lit up and the buttons weren't working. I put it on charge and left it for 2 days and it still isn't working.
Puntuación 0
1 comentario:
+karly styles did you turned the platstation on and then charge or while it was off.
Becouse your ps only charges the controller when it is on..
Also if this dosnt work try the reset button.
Its a little small hole at the back of the controller .
If this also doent work then i think try to sell it and buy a new one. Thank you.
- de
The reset button is a small button on the back of the controller. it is on the left lower side, just above the lower left screw. It looks like a small indent next to the label on the center back of the controller. Stick a paper clip in the button hole for about 10 seconds or until it resets.
Puntuación 0
I am having a similar issue. Haven't played with Move Controllers for a few years. Lights were blinking steadily on the charging dock. But when it came time to connect to the PS3, the light at the bottom blinks rapidly, but stops after a few seconds and nothing. Tried resetting. Still nothing.
Bought new batteries, installed them, charged them, same issue. Light will come on blinking rapidly for a few seconds on the bottom of the controller and nothing. Tried resetting, still nothing.
PS3 Eye blue light is on. Set at wide angle.
Any advice? It's so frustrating!
Puntuación 0
5 comentarios:
I tried resetting it but the button didn’t seem like it was there? Like it just went through and it didn’t hit a button and it’s still not turning on! Idk what to do at this point but buy a Knew one since I checked everything, the battery inside to checking the cables and such...
- de
I have about the same issue.
But I concerns my two 2 moves at once, while they were working a while ago ...
I cannot say, but my be this appende a while after having connected the to the PS4, or
shall this be due to an issue in my block for charging them ? (but it seems ok ...).
Symptoms : they work perfectly (detected, moving, clicking, etc.) but the light ...
I did all : test thème on PS3, PS4, synchronise with PC (note : I syncrhonized with the cable, but with the bluetooh never suceeded to do it completly), reset, change câble... symptoms are the same.
Note that for one of them, the Move is not detected by the PC (Windows says default of usb device ...), but it works exactly as the other on the PS.
Everything works but the light ...
I thought it was the light.
I setup the calibration program, tested the voltage on the led, the green wire sayt about 0.5V wich seems very low, but ...
Il then removed the led to test it ; all 3 colors works perfectly (about 1.2 V low amperage).
I did not do the same test on the other Move, but guess it is the same ...
I then thought the battery may be a bit too low ? (but honestly the moves except the light work perfectly !)
So I bought new batteries and changed them.
Again reset, test on each source (ps3,ps4), but nothing better ... exactly the same symptoms, moves work, not the light (of course I tested calibration, games using moves lauching calibration detecting the moves and clicks but not switching on the ligth, etc).
Best would be to have a small program on PC (Windows or linux) to force a check-up on the move, especially forcing the move to lightup its led.
Or eventually a hidden manipulation on the move to force such an automated check-up ...
Any idea ?
I'm becomming crazy !
- de
@pdelap any update for you? I'm in the same situation where I'm seeing less than 1v across the LED contacts and the LED doesn't light up. The battery is fully charged and has 4.2v.
- de
same here @pdelap any luck? I found a program called psmoveservice that supposed to be able to test the controller, but cant get it to work. It just did not detect my controller at all... might have to connect camera for it to work, have not test that yet.
- de
@Victor Lam yeah idk man
- de
Also looking for an answer to this. Didn’t use my controllers for a little bit because I moved houses and now the sphere lights will not turn on. Both controllers work and connect to the PS4 and function but the lights just won’t turn on. Tried everything suggested here too.
Puntuación 0
I can't find a answer I have the same problem and people just say press the reset button with a pin or something and that doesn't work even if it's connected to your ps4 with a USB
Puntuación 0
Añadir tu respuesta
Navin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 27
Ultimos 30 días: 138
Todo El Tiempo: 41,382
