Modelos de MacBook Pro con pantallas de 13"
Preguntas 5871 Ver todo
won't turn on and does a beeping soung instead
Hi there, I had some problem with my macbook pro a while back, in which the screen was getting blank/frozen and I had to force quit it, and when i tried to turn it back on, it started beeping and would not turn on...then I would wait some hours and it would finally turn on. It was acting like this for a while and I managed to fix it by repairing the disk in disk utility and it was working fine...
Now, since yesterday, it started again, and i had to force quit it, but this time, it is not turning on at all anymore, and it only does the beeping sound when I try to turn it on...firts it does one beeping at a time, and then I force quit it again and turn it on again and it does a faster beeping sequence.
Can anyone help me?
my mac info is:
Mac OS X
version 10.6.8
2.4 GHz Intel Core 2 Duo
4 GB 1067 Mhz DDR3
I never did any work on it, never changed anything...it is just like I got it from the shop.
Thanks
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 4
Comentarios:
Can you supply the last four digits of your serial number so we can ID your system.
por
Agregar un comentario
4 Respuestas
Solución Elegida
3 successive tones, a 5-second pause, 3 successive tones is the RAM integrity error. As Bernd recommended reseat your memory or replace it.
Heres the Apple TN on boot up tones Tone Errors for reference
Fue útil esta respuesta?
Calificación 3
Hi Tania,
how many beeps do you hear? Or is it beeping constantly without an interruption? Sometimes this symptom is caused by the memory. Have a look if it is seated propperly.
Good luck
Calificación 0
Comentarios:
The power on self test error codes either beep or blink the sleep lite in repeating patterns. LCD freezes and beeping comes out of computer to go to a thread that explains what the different ones mean.
por
Start up and hold down the on/off button until led will blink rapidly and mac will start up fine.
Calificación 0
Comentarios:
i am getting repeated 2 beeps and mac wont start up. I have not changed hard disk or anything in my Mac book pro.
Please help
por
Ali - For future reference you posted a Question in the place where only Answers belong. Please use the add comment link to the appropriate Answer, Question or create your own original Question. FWIW 2 beeps mean in "old code" it meant incompatible RAM in "new code" it's no longer listed.
por
What the !&&* is this 100 points or can't vote no. The suggestion did NOT work.
Calificación 0
Comentarios:
Larry please explain what didn't work.
por
Añadir tu respuesta
Tania estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 9
Últimos 7 Días: 54
Últimos 30 Días: 229
Todo El Tiempo: 64,673
