The onboard VGA doesn't work
Anyone has any ideas on a Socket 775 Mobo, there is a problems with the on-board VGA, it doesn't work, the only way, would be a alternative graphic card, but i want to solve this by attemptinf fixing?
Any Ideas??
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 4
Agregar un comentario
5 Respuestas
Respuesta Más Útil
Go to bios on bootup (watch your screen for instructions how--they vary) and check that you don't have on board video turned off in bios. The system board has the ability to do that to prevent conflicts when using a graphic card. If you give us more info on your mobo we can be more specific on how to enter bios settings.
It is possible but not likely your video chip may be bad. Ralph
Fue útil esta respuesta?
Calificación 1
Comentarios:
By doesn't work do you mean no video or poor video? Ralph
por
Does the bios starts? If not it might be a memory problem.Remove one RAM card and turn on the computer. If this doesn't work put the card back and remove the other RAM card and turn on the computer.
Hope this helps.
Calificación 0
Check whether your CPU has onboard graphics, failing that, get a cheap GPU that has VGA.
Calificación 0
Clear cmos battery
Reset bios setting .
restart.......
Calificación 0
Have an issue on this platform that is driving me crazy as I just bought a new motherboard to restore an older Dell Inspiron that is still a great spec but I know I can make it better for cheap.
My LGA775 starts with no POST error beeps but there is a red led just before the PICe x16 slot lit constantly on a refurbished Intel DP45CB mobo, I can't find an answer to what that means online or in the manual.
Anyways, I'm unable to check anything in POST or get to the BIOS as I am getting no video from either of the DVI ports (DVI-I or DVI-D), straight or using a conversion adapter to VGA, DP, or HDMI. Also installed a video card, 2 actually (AMD & NVidia separately). I wanted to put the NVidia card in this build but I can't get any display output. Both cards tested and working so this makes no sense.
  • Converted a Dell i530 OEM to an Intel DP45CB
  • Intel Core 2 Quad x64 2.4GHz CPU
  • Intel Stock Cooler, Corsair H60 or the Dell stock *
* tried all 3, none made a difference
  • Crucial 8GB DDR2 800MHz DRAM
  • Dell Stock LiteOn 350w PSU or ThermalTake 750w PSU*
* tried both even though I knew the 750 wasn't the problem as I tested it and it's double the power of the Dell LiteOn original.
Anybody have any thoughts?
I am cataloging this build to post to YouTube but will also make a guide for here. Just need some feedback. Trying several places for help and happened to open iFixIt and saw all the new categories, figuring it can't hurt to put it out there...
Thanks in advance to whoever can help or has any input.
Calificación 0
Añadir tu respuesta
Solanki estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 5
Últimos 30 Días: 44
Todo El Tiempo: 6,323
