Replace optical drive with SSD?
Is it possible to replace the optical drive of my late 2008 MacBook Pro with an SSD hard drive?
What parts should I buy?
Is there a guide available?
Es esta una buena pregunta?
Hi, yes you can replace your optical drive with an SSD. From what you tell us about your MBP, this guide should be the one you need to follow.
Installing MacBook Pro 15" Unibody Late 2008 and Early 2009 Dual Hard Drive
You will need a caddy or enclosure to hold the SSD on the optical bay area. You need to double check if your MBP uses SATA or ATA to connect to the CD/DVD. To do so, check the hardware info about your MBP and look in both ATA and SATA tabs, the one that shows the CD-DVD will be the type of connector you will need to use.
Fue útil esta respuesta?
You can use iFixit's or any other vendor's 9.5mm kit.
If this answer was helpful please remember to return and mark it Accepted.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 6,006
