wont turn on or charge
my iphone 2g wont turn on either or charge and i am pretty sure its not my computer.Any solutions?
Es esta una buena pregunta?
First thing you might try is to use another USB cable. Check the dock connector carefully for any bend, broken, corroded pins and debris. Clean it with isopropyl alcohol and a toothbrush, or similar tool. After that, try an AC charger. It is easily possible that your battery is at the end of its lifecycle. Replace the battery first, then re-evaluate and see what you have. Follow this guide for the repair and the battery is available right here. Hope this helps, good luck
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,316
