Internal sound not working.
I have tried everything but im having no joy. Sound plays ok through headphones but soon as i unplug them I get NO sound coming from the built in internal speakers.
Please Help.
Big Thanks
Es esta una buena pregunta?
Please Help.
Big Thanks
Could you boot the MacBook from an external source to verify if the problem is hardware or software issue ? Check the headphones port with a flashlight. What is the system preferences -> sound panel -> output status ? Also, repairing permissions can sometimes fix a sound problem.
Fue útil esta respuesta?
Beat me by 27 seconds--+1 for a good answer. Ralph
Two possibilities come to mind. 1. The speaker connection to the logic board is faulty or 2. the headphone jack has a problem and is not connecting the speakers when you remove the headphones. You can try looking at the jack without removing the top cover but I suspect you will need to take it apart. Ralph
Could be a broken tip on the audio jack. +vote for the good "late" answer
With a broken tip inside the sound port the OP would have no heaphones sound and he says that << sound plays ok through headphones>>.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 896
1 comentario
third time you asked the same question in 7 hours
- de mayer
