Introducción
it`s easy and very quick replacement. it could be completed even with fingerskate screwdriver, but i used simple philips 1,7 from my toolkit.
samsung sgh x820 samsung sgh x820 samsung sgh x820
  • samsung sgh x820
Agregar Comentario
after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver. after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver. after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
  • after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
Agregar Comentario
now we have two more screws hiden first time i used needle. this time i took a blade. removing the last two philipps-head screws.
  • now we have two more screws hiden
  • first time i used needle. this time i took a blade.
  • removing the last two philipps-head screws.
Agregar Comentario
be carefull. the phone is thin and you should push on two hooks two open cover case.
  • be carefull. the phone is thin and you should push on two hooks two open cover case.
Agregar Comentario
now you should take of the square metal  in the middle of your phone to eject display.
  • now you should take of the square metal in the middle of your phone to eject display.
  • i used plastic spudger
Agregar Comentario
the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
  • the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
sergeygraf
Miembro Desde 24/10/10
161 Reputación
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 6
Todo El Tiempo: 1,003
