Introducción
Replace the rear case on your iPod shuffle for a shiny new clip.
Partes
No se requieren partes.
Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
  • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
  • Be careful when using a metal spudger, as you may scratch the outer case.
Agregar Comentario
Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case. Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
Agregar Comentario
Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
  • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
  • Pry the rear case away from the front case.
Agregar Comentario
Lift the bottom of the rear case and remove it from the rest of the iPod.
  • Lift the bottom of the rear case and remove it from the rest of the iPod.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Matthew Newsom
Miembro Desde 05/01/10
31,468 Reputación
93 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 9
Últimos 30 Días: 25
Todo El Tiempo: 6,273
