Introducción
Replace the damaged headphone jack to hear those sweet tunes again.
Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
  • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
  • Be careful when using a metal spudger, as you may scratch the outer case.
Agregar Comentario
Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case. Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
Agregar Comentario
Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
  • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
  • Pry the rear case away from the front case.
Agregar Comentario
Lift the bottom of the rear case and remove it from the rest of the iPod.
  • Lift the bottom of the rear case and remove it from the rest of the iPod.
Agregar Comentario
Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
Agregar Comentario
Remove the single Phillips screw securing the logic board to the front case.
  • Remove the single Phillips screw securing the logic board to the front case.
Agregar Comentario
Peel the battery up from the front case with an iPod opening tool.
  • Peel the battery up from the front case with an iPod opening tool.
  • Remove the logic board and battery from the iPod.
Agregar Comentario
Pry the headphone jack from the front case with an iPod opening tool.
  • Pry the headphone jack from the front case with an iPod opening tool.
  • Don't attempt to remove the headphone jack yet, it is connected to the shuffle switch.
Agregar Comentario
Using the pointed tip of a spudger, push the shuffle switch in to separate it from the front case.
  • Using the pointed tip of a spudger, push the shuffle switch in to separate it from the front case.
Agregar Comentario
Remove the headphone jack and shuffle switch from the front case.
  • Remove the headphone jack and shuffle switch from the front case.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Matthew Newsom
Miembro Desde 05/01/10
31,407 Reputación
93 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 8
Últimos 30 Días: 38
Todo El Tiempo: 10,720
