Introducción
The plastic part on the bottom of the iPod.
Before opening your iPod, ensure that the hold switch is in the locked position.
  • Before opening your iPod, ensure that the hold switch is in the locked position.
Agregar Comentario
When removing the the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
  • When removing the the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
  • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic bezel
  • Lift the bottom bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
iRobot
Miembro Desde 24/09/09
1 Reputación
750 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 11
Todo El Tiempo: 13,102
