Introducción
The colored metal front half of your iPod.
Apple designed their new iPods to be very difficult to take apart without destroying major components. Because of the metal faceplate, the metal backing, and the 13 (yes, 13) metal clips holding the case together, this is one of the toughest iPods to disassemble.
  • Apple designed their new iPods to be very difficult to take apart without destroying major components. Because of the metal faceplate, the metal backing, and the 13 (yes, 13) metal clips holding the case together, this is one of the toughest iPods to disassemble.
  • Proceed with caution and the warning that you may significantly damage your iPod beyond its present condition. Also, you may want a few extra pairs of plastic opening tools during installation, as they are easy to ruin when opening the iPod. Have fun!
  • Before opening your iPod, ensure that the hold switch is in the locked position.
If you're meticulous, the job can perfectly be done, without any of the recommended tools. I hadn't the time to order them, so I opened my iPod with the large blade of my Victorinox swiss army knife. By just following the instruction I succeeded in releasing all of the metal tabs all around the iPod, and didn't damage any of them. You can clearly hear them "declipsing". I think the blade of the Victorinox is thiner than the putty knife, the only thing you have to take care of, is not to cut the black or silver painting of the front of the case, but if you are used to cut with a knife, you should succeed. Just be aware that it is however a difficult job !
jcfsystems - Contestar
Thank you for these instructions - my dead iPod classic (that died whilst attached to an ipod dock during a heavy thunderstorm which took out the dock too) is now working again. Opening the case took me 40 minutes and 7 plastic case openers not to mention very sore hands but the rest of the process worked fine. thanks again
Stuart Hutchesson - Contestar
Opened it up with MANY super thin nylon guitar picks in less than a minute starting from the two tabs on the bottom - I used the putty knife in my shop for wood filler and patching walls :)
cmguitar - Contestar
Opening this iPod is challenging. Don't get discouraged if it takes you a few tries before the iPod is opened. One thing to notice is the angle of the plastic opening tool's tip while inserting it into the iPod. Ideally, the angle should be as vertical as possible while still clearing the edge of the rear panel.
  • Opening this iPod is challenging. Don't get discouraged if it takes you a few tries before the iPod is opened. One thing to notice is the angle of the plastic opening tool's tip while inserting it into the iPod. Ideally, the angle should be as vertical as possible while still clearing the edge of the rear panel.
  • Insert a plastic opening tool into the seam between the front and back of the iPod.
I have with luck (several times) used the metal spudger to create a small initial gap.
But be careful, it's easy to severely scratch the iPod.
rousp - Contestar
right here, you should insert a picture of the little clips on the rails inside the back of the ipod, so that we can visualise what we're trying to undo, & get a better idea of which way to bend, which way NOT to bend the tools.
duncanrmi - Contestar
Insert another plastic opening tool into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools.
  • Insert another plastic opening tool into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools.
Agregar Comentario
At an angle, carefully insert a putty knife about 1/8 inch into the seam between the two opening tools.
  • At an angle, carefully insert a putty knife about 1/8 inch into the seam between the two opening tools.
  • There are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
  • Once the putty knife has cleared the lip of the rear panel, pivot the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the gap between the opening tools.
Agregar Comentario
Push with your fingers on the rear panel behind the putty knife to minimize bending. Slowly flex the putty knife, as shown in the picture, to ensure that most of the metal tabs on this side of the iPod are disengaged.
  • Push with your fingers on the rear panel behind the putty knife to minimize bending. Slowly flex the putty knife, as shown in the picture, to ensure that most of the metal tabs on this side of the iPod are disengaged.
  • The theory behind this method is, rather than attempting to not bend the rear panel at all, to bend it in a favorable manner that allows you to easily restore it later. Therefore, any bend in the sides of the rear panel should be drawing the lip of the rear panel away from the iPod, rather than pushing out on the curved surface. This method also disengages as many of the side clips as possible.
Agregar Comentario
Remove the putty knife from the iPod and reinsert it closer to the corner of the iPod, using the same wiggle method as before.
  • Remove the putty knife from the iPod and reinsert it closer to the corner of the iPod, using the same wiggle method as before.
  • If at all possible, do not bend the corner of the rear panel.
Agregar Comentario
Near the headphone jack, insert a plastic opening tool into the seam between the front and back of the iPod.
  • Near the headphone jack, insert a plastic opening tool into the seam between the front and back of the iPod.
  • You may find it easier to carefully flex the putty knife downward in order to create more of a gap for the opening tool, but be sure not to bend the corner of the rear panel!
Agregar Comentario
Near the center of the display, carefully insert a metal spudger into the gap created by the plastic opening tool.
  • Near the center of the display, carefully insert a metal spudger into the gap created by the plastic opening tool.
  • It is easy to create a noticeable bump in the rear panel here that is difficult to repair. When prying the tab free, try to have the metal spudger pivot on the edge of the rear panel rather than bending the rear panel outward.
  • Using the metal spudger, disengage the single clip on the top of the iPod.
Agregar Comentario
Near the other top corner, insert a plastic opening tool into the seam between the front and back of the iPod
  • Near the other top corner, insert a plastic opening tool into the seam between the front and back of the iPod
Agregar Comentario
On the other side, insert a plastic opening tool into the seam between the front and back of the iPod.
  • On the other side, insert a plastic opening tool into the seam between the front and back of the iPod.
  • You may find it easier to angle the opening tool stuck in the top corner in order to create a sufficient gap.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the opening tool from the top corner and insert it into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools (as done on the other side).
  • Remove the opening tool from the top corner and insert it into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools (as done on the other side).
Agregar Comentario
  • Again, there are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
  • Once the putty knife has cleared the lip of the rear panel, angle the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the iPod via the gap between the plastic opening tools.
  • Push with your fingers on the rear panel behind the putty knife to minimize bending. Ever so slightly flex the putty knife to ensure that most of the metal tabs on this side of the iPod are disengaged.
Agregar Comentario
The metal clips near the corners are notorious for tenaciously gripping the front panel. It is necessary to disengage these clips in order to open the iPod.
  • The metal clips near the corners are notorious for tenaciously gripping the front panel. It is necessary to disengage these clips in order to open the iPod.
  • Carefully insert a metal spudger into the area near the stubborn metal clip.
Agregar Comentario
Gently wiggle the metal spudger down so that it is all the way in the rear panel.
  • Gently wiggle the metal spudger down so that it is all the way in the rear panel.
Agregar Comentario
Gently begin to disengage the clip from the front panel.
  • Gently begin to disengage the clip from the front panel.
Agregar Comentario
Continue to push up on the front panel with the metal spudger until the metal clip releases.
  • Continue to push up on the front panel with the metal spudger until the metal clip releases.
Agregar Comentario
There are two ribbon cables connecting the rear panel to the rest of the iPod. In the following step, be careful not to damage these ribbon cables.
  • There are two ribbon cables connecting the rear panel to the rest of the iPod. In the following step, be careful not to damage these ribbon cables.
  • Grasp the front panel assembly with one hand and the rear panel with the other.
  • Take a deep breath!
  • Gently (GENTLY) disengage the remaining clips on the rear panel by pulling the tops of the front and rear panels away from each other (think of the bottom of the iPod as a hinge), taking great care not to damage the ribbon cables holding the two halves together.
Agregar Comentario
Use a spudger to slide up the connector holding the orange battery ribbon in place. You only need to lift the locking bar up about 2 mm to free the cable.
  • Use a spudger to slide up the connector holding the orange battery ribbon in place. You only need to lift the locking bar up about 2 mm to free the cable.
  • Slide the orange battery ribbon out of its connector.
If the small battery black/white connector pumps out of the ipod when you are trying to unplug the cable...REMEMBER the "U" black shape is meant to be just in the same direction as the blue plastic "U" beside it. If you plug it back in the wrong way it will display "Charging please wait..." forever!.
riverate - Contestar
How did you get the black battery piece to stay in after it popped out?
Katrina Frantz -
I knocked this little bit out too! Any tips to get it back in? Soldering?
David Ewing -
Place the rear panel next to the iPod, being careful not to strain the orange headphone jack cable.
  • Place the rear panel next to the iPod, being careful not to strain the orange headphone jack cable.
Agregar Comentario
Lift the hard drive up with one hand so you can access the headphone jack ribbon beneath.
  • Lift the hard drive up with one hand so you can access the headphone jack ribbon beneath.
  • Use a spudger to flip up the plastic tab holding the headphone jack ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
  • Slide the orange headphone jack ribbon out of its connector.
  • The rear panel is now free from the iPod.
Agregar Comentario
Now to repair the damage caused by liberating the internal parts of the iPod Classic! It is highly likely that at least one of the metal clips in the lower case has been bent upward. These clips must all be pointing downward in order to reinstall the rear panel.
  • Now to repair the damage caused by liberating the internal parts of the iPod Classic! It is highly likely that at least one of the metal clips in the lower case has been bent upward. These clips must all be pointing downward in order to reinstall the rear panel.
Agregar Comentario
Take the broad, flat side of the metal spudger and push the clip down, taking care not to tear the thin metal rail from the rear panel.
  • Take the broad, flat side of the metal spudger and push the clip down, taking care not to tear the thin metal rail from the rear panel.
  • Be careful not to damage any of the headphone jack parts while shaping these clips!
Agregar Comentario
On a clean, hard surface, lay the rear panel on its side. Carefully but firmly push down on it, rolling the entire lip side back into its proper spot.
  • On a clean, hard surface, lay the rear panel on its side. Carefully but firmly push down on it, rolling the entire lip side back into its proper spot.
  • It may be necessary to do this multiple times in order to achieve optimal straightness on the sides. It is better to have the edges of the case pushed in slightly too far rather than not far enough, because the reseating of the front panel will bend the rear panel into its correct alignment.
  • Now that the rear panel is back to a beautiful condition, you can move on to repairing the iPod!
Agregar Comentario
Rotate the hard drive out of the framework and place it so that the connector is facing up.
  • Rotate the hard drive out of the framework and place it so that the connector is facing up.
  • Use a spudger to flip up the plastic tab holding the orange hard drive ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
Agregar Comentario
Slide the orange hard drive ribbon cable directly out of its connector.
  • Slide the orange hard drive ribbon cable directly out of its connector.
  • If you are replacing the hard drive in your iPod and it did not come with the rubber mounting brackets and foam padding, transfer these items from your old drive to the replacement drive.
Agregar Comentario
Remove the three Phillips screws securing the front panel to the metal framework.
  • Remove the three Phillips screws securing the front panel to the metal framework.
Rotate the iPod 180 degrees and remove the three Phillips screws securing the front panel to the metal framework on the other side.
  • Rotate the iPod 180 degrees and remove the three Phillips screws securing the front panel to the metal framework on the other side.
Agregar Comentario
Carefully work around the edges of the iPod to separate the front panel from the gray metal framework.
  • Carefully work around the edges of the iPod to separate the front panel from the gray metal framework.
  • You may meet some resistance, as there is a mild adhesive used to help hold the two pieces together.
I would suggest prying with a tool on one of the lips that holds the front place on, but do NOT pry on one near the LCD screen or you may damage the screen. Also, don't forget there is an extra small latch on the top of the LCD that has to be loosened too.
iTronics Repair - Contestar
I pressed gently on the click wheel on the play botton side first to help unlock the glue. Keep away from the screen side best you can.
Stephen Sherry - Contestar
Lift the framework (including the attached screen, logic board, and click wheel) away from the front panel.
  • Lift the framework (including the attached screen, logic board, and click wheel) away from the front panel.
  • Make sure that the click wheel button is in place before reinstalling the framework in the front panel.
Agregar Comentario
The front panel is now free from the iPod.
  • The front panel is now free from the iPod.
Agregar Comentario
Conclusión
37 personas más completaron esta guía.
iRobot
Miembro Desde 24/09/09
1 Reputación
750 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 44
Últimos 30 Días: 162
Todo El Tiempo: 57,852
