Introducción
Battery not lasting long? Swap it out.
Before opening your iPod, ensure that the hold switch is in the locked position.
  • Before opening your iPod, ensure that the hold switch is in the locked position.
Agregar Comentario
Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
  • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
  • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
Agregar Comentario
Continue to run the opening tool along the side of the case until all five tabs have been released.
  • Continue to run the opening tool along the side of the case until all five tabs have been released.
Agregar Comentario
Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
  • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
Agregar Comentario
Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
  • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
Agregar Comentario
Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
  • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
Agregar Comentario
Peel up the metallic tape attached to the top of the battery.
  • Peel up the metallic tape attached to the top of the battery.
Agregar Comentario
Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
  • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
Agregar Comentario
Lift up the end of the hard drive near the Firewire port to allow easy access to the battery connector.
  • Lift up the end of the hard drive near the Firewire port to allow easy access to the battery connector.
Agregar Comentario
Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
  • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
Agregar Comentario
Conclusión
12 personas más completaron esta guía.
iRobot
Miembro Desde 24/09/09
1 Reputación
750 Guías creadas
Nice easy fix. Modern batteries are twice the capacity too. These old gen iPods are great. Nice to have an apple product not made in China.
peter barker - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 14
Últimos 30 Días: 59
Todo El Tiempo: 19,981
