Saltar al contenido principal
iPhone 4S Battery Replacement
Qué necesitas
  1. iPhone 4S Battery Replacement, Pentalobe Screws: paso 1, imagen 1 de 1
    • Remove the Bottom Pentalobe Screws next to the charger connecter.
    • It is recommended that you use a small 5-Point screwdriver.
    • Remember to make sure your iPhone is fully turned off before tearing it down, to prevent serious injury.
  2. iPhone 4S Battery Replacement, Back Panel Removal: paso 2, imagen 1 de 2 iPhone 4S Battery Replacement, Back Panel Removal: paso 2, imagen 2 de 2
    • Push the back panel towards the top edges of the iPhone. Doing this should allow the back to slide off.
    • Do NOT apply so much pressure. Especially if your iPhone is cracked.
    • Do not rush it! Time is key.
  3. iPhone 4S Battery Replacement, Battery Screws: paso 3, imagen 1 de 1
    • Remove these two screws that are securing the battery connecter to the Logic Board.
    • Remember to focus and pay attention. So you don't accidentally slip and pierce the Battery!
    • For the bottom screw, it is recommended that you use a 1.5 mm Screwdriver, and a 1.7 mm for the top screw.
  4. iPhone 4S Battery Replacement, Battery Strip: paso 4, imagen 1 de 1
    • Locate and pull the Plastic tab to pull out battery. Make sure to pry up outsides of battery on other sides as well.
    • Do not pull the plastic tab to hard, as it can easily rip!
  5. iPhone 4S Battery Replacement, Battery Removal: paso 5, imagen 1 de 1
    • Carefully remove the battery.
    • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone once its all finished.
Conclusión
60 personas más completaron esta guía.
Cole Anello
Miembro Desde 11/01/16
1,986 Reputación
1 Guía escrita
Un comentario
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 36
Ultimos 30 días: 152
Todo El Tiempo: 20,667
