Saltar al contenido principal
iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
Resumen del Video
  1. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement, Dock Connector: paso 1, imagen 1 de 1
    • If present, remove the small strip of tape covering one of the dock connector screws.
  2. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: paso 2, imagen 1 de 2 iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to flip up the retaining flap on the home button ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  3. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: paso 3, imagen 1 de 1
    • Use a pair of tweezers to pull the home button ribbon cable out of its socket.
    • There are tiny components on the back side of the ribbon, so be careful not to damage them upon ribbon removal.
  4. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: paso 4, imagen 1 de 1
    • Carefully pull the rubber microphone holder out of its tube in the bottom edge of the iPhone.
  5. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: paso 5, imagen 1 de 1
    • Remove the two 1.3 mm Phillips screws securing the dock connector to the case of the iPhone.
  6. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: paso 6, imagen 1 de 1
    • Remove the tiny rubber spacer near the dock connector.
  7. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: paso 7, imagen 1 de 2 iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: paso 7, imagen 2 de 2
    • Use the edge of a plastic opening tool to peel the dock connector and its cable off the black plastic case of the iPhone.
    • If you are replacing the dock connector with a new part, make sure to transfer the rubber casing around the microphone. You can do this using a spudger.
  8. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: paso 8, imagen 1 de 2 iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: paso 8, imagen 2 de 2
    • Pry the dock connector away from its opening at the bottom of the iPhone.
    • Remove the dock connector.
  9. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement, Speaker Enclosure: paso 9, imagen 1 de 1
    • Speaker enclosure remains.
Conclusión
19 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,182 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,521 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 10,623
