Introducción
Apple has substituted the two bottom Phillips screws near the dock connector with 5-point "Pentalobular" screws.
This guide will illustrate how to replace the Pentalobe screws with good ol' regular Phillips screws.
Herramientas
No se requieren herramientas.
Before we proceed, let's make sure you have the correct tools for the job.
  • Before we proceed, let's make sure you have the correct tools for the job.
  • iFixit's iPhone 4/4S Liberation Kit includes:
    • One 5-Point Pentalobe screwdriver
    • One #000 Phillips screwdriver
    • Two 3.6 mm "Liberation" Phillips screws
  • Are you ready to break the shackles of hardware oppression and liberate your iPhone? Let's rock!
Agregar Comentario
Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector. Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
  • Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Peel and remove the two 3.6 mm Phillips screws from the iPhone Liberation Card. Both the Phillips and Pentalobe screws are really small. How small? See for yourself (highlighted in the second picture).
  • Peel and remove the two 3.6 mm Phillips screws from the iPhone Liberation Card.
  • Both the Phillips and Pentalobe screws are really small. How small? See for yourself (highlighted in the second picture).
Agregar Comentario
Insert the two 3.6 mm Phillips screws into the screw holes using the provided #000 Phillips screwdriver.
  • Insert the two 3.6 mm Phillips screws into the screw holes using the provided #000 Phillips screwdriver.
  • Huzzah! Your iPhone is now liberated from those pesky "Pentalobular" screws.
Agregar Comentario
Conclusión
43 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 9
Últimos 30 Días: 38
Todo El Tiempo: 32,021
