Introducción
The front panel assembly, including the digitizer, ear speaker, and home button, can be replaced on the iPhone 3G.
Qué necesitas
Resumen del Video
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
Ribbon cable "1" is connected with a plug style connector. The block at the end of the cable is the plug which is simply pushed into a socket on the circuit board. No other locking mechanism is used.
185 personas más completaron esta guía.
Un comentario
Be very careful opening the display. On my phone, connector #4 was stuck to the inside surface of the display. The display was difficult to open and released suddenly. Although the display didn't open as far as shown in picture #2, and certainly less than shown in picture #3, when it released, it tore connector #4 completely away from the dock connector assembly. So, in addition to needing a new display assembly to fix a broken home button, I now need to replace the dock connector as well.
