Saltar al contenido principal
iMac Intel 24" EMC 2267 RAM Replacement
Qué necesitas
  1. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: paso 1, imagen 1 de 1
    • Lay your iMac front side down on a table with the lower edge facing yourself.
    • Loosen the single Phillips screw PH#2 in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: paso 2, imagen 1 de 2 iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: paso 2, imagen 2 de 2
    • Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay. Formatting help
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
  3. iMac Intel 24" EMC 2267 RAM Replacement: paso 3, imagen 1 de 1
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
Conclusión
35 personas más completaron esta guía.
johann beda
Miembro Desde 09/13/10
2,483 Reputación
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 45
Todo El Tiempo: 25,863
