Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
iMac Intel 24" EMC 2111 RAM Replacement
Qué necesitas
  1. iMac Intel 24" EMC 2111 RAM Replacement, Access Door: paso 1, imagen 1 de 2 iMac Intel 24" EMC 2111 RAM Replacement, Access Door: paso 1, imagen 2 de 2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. iMac Intel 24" EMC 2111 RAM Replacement, RAM: paso 2, imagen 1 de 1
    • Pull both RAM arms away from the iMac to release both RAM chips from their sockets.
  3. iMac Intel 24" EMC 2111 RAM Replacement: paso 3, imagen 1 de 1
    • Pull both RAM chips out of their slots.
    • During reinstallation, make sure both RAM arms are fully rotated outward before inserting the RAM chips. Use your thumbs to seat the new RAM chips into their sockets and then press the RAM arms back into the iMac.
    • It is normal to encounter a fair amount of resistance when pushing the RAM arms back into the iMac.
Conclusión
20 personas más completaron esta guía.
3Guía Comentarios
Hi, i'd love to make some upgrades but can't remember which imac 24is mine. Where can I read it? Can I switching it on? Thanks
Fabrizio Lazzeretti - Contestar Compartir
hello, i already have 2GB, is it possible to add more? thank you!
connie dekker - Contestar Compartir
via Everymac.com
Standard RAM: 1 GB Maximum RAM: 4 GB*
Details: 1 GB of RAM is installed as two 512 MB SO-DIMM modules.
*Apple officially supports 3 GB of RAM, but third-parties have been able to upgrade the system to 4 GB of RAM using two 2 GB memory modules
emaginechild - Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 22
Todo El Tiempo: 17,104
