Introducción
Use this guide to replace a blown left speaker.
Loosen the two Phillips screws securing the access door to your iMac. Both screws remain captive within the access door.
  • Loosen the two Phillips screws securing the access door to your iMac.
  • Both screws remain captive within the access door.
  • Remove the access door.
Agregar Comentario
Remove the following screws along the lower edge of your iMac:
  • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw
My iMac had four 6mm T8 Torx screws (so not one 8mm screw)
floor - Contestar
Lay your iMac stand-side down on a flat surface. To lift the front bezel off the iMac, simultaneously:
  • Lay your iMac stand-side down on a flat surface.
  • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
  • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
My iMac did not have the "small bridge of material" mentioned, however the bezel just lifted off easily.
maccentric - Contestar
Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge. The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case. Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
  • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
  • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
  • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
Agregar Comentario
If necessary, remove the strip of tape covering the microphone cable connector.
  • If necessary, remove the strip of tape covering the microphone cable connector.
  • The microphone connector is located near the inside of top edge of your iMac.
Agregar Comentario
Disconnect the microphone cable. Disconnect the camera cable by pulling its connector away from the socket on the camera board. The camera cable connector and socket are delicate and easily bent. Remove with caution.
  • Disconnect the microphone cable.
  • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
  • The camera cable connector and socket are delicate and easily bent. Remove with caution.
I found it easier not to remove the cables connecting camera and microphone, but rather to lean the plastic frame agains a pile of books so that it could rest almost vertical avoiding the need to disconnect those two sensitive cables.
Stefano C - Contestar
I agree that for a simple, quick battery change, don't risk damaging those delicate wires. Ignore Step 6 and instead of disconnecting the mic and camera wires, keep them in place and just have a friend hold the plastic frame up while you change the battery, or prop it up as mentioned by Stefano C above.
WT Kwok - Contestar
Make sure you double check the new logic board for the presence of the GPU assembly before installing. I stupidly installed a new board without moving the GPU from the old one first. So i guess you can say this guide worked for me twice. :)
Trevor Kearsey - Contestar
Peel the two highlighted EMI shield tabs off the frame of the LCD. Peel the two highlighted EMI shield tabs off the frame of the LCD.
  • Peel the two highlighted EMI shield tabs off the frame of the LCD.
Agregar Comentario
Remove the two T6 Torx screws securing the display data cable to the logic board.
  • Remove the two T6 Torx screws securing the display data cable to the logic board.
Wait, we need a T6 screwdriver as well?
I purchased the T8 and T10 from your site as per the parts list above and now am here with an opened iMac on the dining room table unable to continue :/
Stephen Alianiello - Contestar
Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
  • Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
Agregar Comentario
Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board. De-route the inverter cable from its location next to the CPU fan.
  • Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
  • De-route the inverter cable from its location next to the CPU fan.
Agregar Comentario
Before attempting this step, we recommend laying your iMac stand-side down on a table to avoid the display falling down.
  • Before attempting this step, we recommend laying your iMac stand-side down on a table to avoid the display falling down.
  • Remove the eight T8 Torx screws securing the display assembly to the rear case.
  • It is helpful to use a thin magnetized screwdriver to remove these screws.
Agregar Comentario
Remove the display assembly from the iMac.
  • Remove the display assembly from the iMac.
Agregar Comentario
Peel back the piece of EMI tape connecting the bottom edge of the right speaker to the metal frame of the iMac. Peel the tape away from the lower corner of the right speaker.
  • Peel back the piece of EMI tape connecting the bottom edge of the right speaker to the metal frame of the iMac.
  • Peel the tape away from the lower corner of the right speaker.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
De-route the right-hand speaker's cable from between the logic board and the optical drive fan. Disconnect the cable from the logic board.
  • De-route the right-hand speaker's cable from between the logic board and the optical drive fan.
  • Disconnect the cable from the logic board.
Agregar Comentario
Remove the 26 mm T10 Torx screw securing the right speaker to the iMac.
  • Remove the 26 mm T10 Torx screw securing the right speaker to the iMac.
Agregar Comentario
Pull the right speaker away from the logic board and remove it from the iMac.
  • Pull the right speaker away from the logic board and remove it from the iMac.
Agregar Comentario
Use the flat end of a spudger to pry both antenna connectors off their sockets on the AirPort card. The black antenna attaches closest to the bottom edge of the iMac.
  • Use the flat end of a spudger to pry both antenna connectors off their sockets on the AirPort card.
  • The black antenna attaches closest to the bottom edge of the iMac.
Agregar Comentario
Use both fingertips to disconnect the camera and microphone cable from its socket on the logic board.
  • Use both fingertips to disconnect the camera and microphone cable from its socket on the logic board.
  • Pull the connector perpendicular to the face of the logic board.
Agregar Comentario
Pull the optical drive fan connector toward the top edge of the iMac to disconnect it from the logic board.
  • Pull the optical drive fan connector toward the top edge of the iMac to disconnect it from the logic board.
Agregar Comentario
Pull the left speaker connector toward the top edge of the iMac to disconnect it from the logic board.
  • Pull the left speaker connector toward the top edge of the iMac to disconnect it from the logic board.
Agregar Comentario
Pull the optical drive thermal sensor connector toward the right side of the iMac to disconnect it from its socket.
  • Pull the optical drive thermal sensor connector toward the right side of the iMac to disconnect it from its socket.
Agregar Comentario
If necessary, remove the strip of tape covering the optical drive connector.
  • If necessary, remove the strip of tape covering the optical drive connector.
Agregar Comentario
Gently pull the cable retainer on the optical drive cable ZIF socket toward the right side of the iMac. The retainer should move about 1 mm and stop. Do not attempt to remove the retainer. Pull the optical drive ribbon cable out of its socket, being careful not to rip it in the process.
  • Gently pull the cable retainer on the optical drive cable ZIF socket toward the right side of the iMac.
  • The retainer should move about 1 mm and stop. Do not attempt to remove the retainer.
  • Pull the optical drive ribbon cable out of its socket, being careful not to rip it in the process.
Agregar Comentario
Disconnect the hard drive thermal sensor and hard drive fan cables from the logic board by pulling their connectors toward the top edge of the iMac.
  • Disconnect the hard drive thermal sensor and hard drive fan cables from the logic board by pulling their connectors toward the top edge of the iMac.
Agregar Comentario
Pull the CPU fan connector toward the left edge of the iMac to disconnect it from the logic board.
  • Pull the CPU fan connector toward the left edge of the iMac to disconnect it from the logic board.
Agregar Comentario
Disconnect the power button cable from the logic board. Pull its connector perpendicular to the face of the logic board.
  • Disconnect the power button cable from the logic board.
  • Pull its connector perpendicular to the face of the logic board.
Agregar Comentario
Use the flat end of a spudger to pry the single Bluetooth antenna off its socket on the Bluetooth board.
  • Use the flat end of a spudger to pry the single Bluetooth antenna off its socket on the Bluetooth board.
Agregar Comentario
Pull the ambient temperature sensor cable perpendicular to the face of the logic board to disconnect it from its socket.
  • Pull the ambient temperature sensor cable perpendicular to the face of the logic board to disconnect it from its socket.
Agregar Comentario
Disconnect the DC-In cable from the logic board by pulling its cable toward the right side of the iMac while depressing its locking mechanism. It is helpful to use a spudger and pry from alternating sides of the connector to help "walk" it out of its socket.
  • Disconnect the DC-In cable from the logic board by pulling its cable toward the right side of the iMac while depressing its locking mechanism.
  • It is helpful to use a spudger and pry from alternating sides of the connector to help "walk" it out of its socket.
Agregar Comentario
Pull the hard drive SATA data cable perpendicular to the face of the logic board to disconnect it from its socket. To avoid damaging the socket on the logic board, we recommend using a metal spudger to help separate the SATA data cable and its socket. To avoid damaging the socket on the logic board, we recommend using a metal spudger to help separate the SATA data cable and its socket.
  • Pull the hard drive SATA data cable perpendicular to the face of the logic board to disconnect it from its socket.
  • To avoid damaging the socket on the logic board, we recommend using a metal spudger to help separate the SATA data cable and its socket.
Agregar Comentario
Peel the foam tape off the top edge of the heat sink framework.
  • Peel the foam tape off the top edge of the heat sink framework.
Agregar Comentario
Remove the following ten screws:
  • Remove the following ten screws:
    • Three 6.6 mm T10 Torx fine thread screws
    • Three 7 mm T10 Torx coarse thread screws
    • Two 9.3 mm T10 Torx coarse thread screws
    • Two 5.3 mm T10 Torx coarse thread screws
Agregar Comentario
Pull the right edge of the logic board slightly away from the rear case to dislodge the rear I/O ports from their bezel. Tilt the top edge of the board away from the rear case and lift the logic board assembly out of the rear case, minding any cables that may get caught.
  • Pull the right edge of the logic board slightly away from the rear case to dislodge the rear I/O ports from their bezel.
  • Tilt the top edge of the board away from the rear case and lift the logic board assembly out of the rear case, minding any cables that may get caught.
  • When reinstalling the logic board, it is helpful to use tape to temporarily tuck the cables out of the way until the board is properly seated in the rear case.
  • During reassembly of the logic board, pay attention to the position of the I/O connectors. When the board is back in the case, insert a USB or Thunderbolt cable into one of the connectors to align it perfectly.
Agregar Comentario
Lift the optical drive fan off the plastic posts protruding from the rear case.
  • Lift the optical drive fan off the plastic posts protruding from the rear case.
  • During reinstallation, be sure to re-route the cable the way you found it.
Agregar Comentario
Remove the pieces of tape securing the left speaker cable to the rear case.
  • Remove the pieces of tape securing the left speaker cable to the rear case.
  • We have found it easier to just cut the tape near the cable for removal. During reinstallation, simply apply a new piece of tape over the cable.
Agregar Comentario
De-route the left speaker cable from beneath the framework near the center of the iMac.
  • De-route the left speaker cable from beneath the framework near the center of the iMac.
Agregar Comentario
Peel back the strip of EMI tape near the bottom edge of the left speaker. Pull the EMI tape away from the bottom corner of the left speaker.
  • Peel back the strip of EMI tape near the bottom edge of the left speaker.
  • Pull the EMI tape away from the bottom corner of the left speaker.
Agregar Comentario
Remove the 38 mm T10 Torx screw securing the left speaker to the rear case.
  • Remove the 38 mm T10 Torx screw securing the left speaker to the rear case.
Agregar Comentario
Pull the left speaker out of the iMac, minding any cables that may get caught.
  • Pull the left speaker out of the iMac, minding any cables that may get caught.
  • If your replacement left speaker does not have an ambient temperature sensor attached, use the edge of a spudger to peel it off the existing speaker and transfer it to your new speaker.
Agregar Comentario
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 7
Todo El Tiempo: 2,672
