Introducción
Use this guide to upgrade your CPU.
Qué necesitas
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door from your iMac.
Herramienta utilizada en este paso:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Remove the following four screws securing the power supply to the outer case:
Two 22.2 mm fine-thread T10 Torx
One 25 mm coarse-thread T10 Torx
One 9 mm coarse-thread T10 Torx
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-Out cable still attaching it to the iMac.
Disconnect the DC-In cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-In connector away from the power supply.
Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
Pull the left and right speaker connectors toward the right side of the iMac to disconnect them from the logic board.
Disconnect the following cables by pulling their connectors toward the top edge of the iMac:
Camera cable
Hard drive thermal sensor
Hard drive fan
Microphone
Disconnect the following cables by pulling their connectors toward the right edge of the iMac:
Ambient temperature sensor
Bluetooth cable
Use a pair of tweezers to lift the heat sink thermal sensor connector straight up out of its socket on the logic board.
Carefully pull the CPU retaining bar away from the CPU socket.
Rotate the bar toward the center of the logic board.
30 personas más completaron esta guía.
19 comentarios
Hello I fixit.!
Hello a lot of congrats! for your site! is very very helpfully for Mac Users
so. i have a question please if you want to help me.!
i have an i mac 21,5 late2009
3,06ghz intel core 2 duo
i have an idea to change the processor to. intel core i5 3,3 Ghz core
can be compatible . on main board .
thanks a lot for your time
These 21.5" (and 27") iMacs came with only either Core 2 Duo E7600 (3.06Ghz, 2 core, 65W TDP, LGA 775) or Core 2 Duo E8600 (3.33GHz, 2 core, 65W TDP, LGA 775), which are incompatible with any Core i5 as there are no Core i5's that were available on the LGA 775 socket these systems.
You might be able to upgrade to a Core 2 Quad Q9505S or Q9550S (2.83GHz, 4 core, 65W TDP LGA 775) which would provide 2 extra cores than the E7600/E8600 and work in the same socket but drop the max clocks to stay at the same 65W TDP power limit.
I installed a Q6700 Core 2 Quad into my late 2009 Core 2 Duo iMac.
Sadly it is not working, only recognize 2 Cores instead 4 under Windows 7.
Booting in the lates Mac OS, it gives up Kernel panic.
Any advise?
The Core 2 Quad Q6700 is a 105W TDP processor and the 21.5" & 27" iMacs running the Core 2 Duo E7600/E8600 only support 65W TDP LGA 775 Core 2 processors. If you wish to upgrade from the Core 2 Duo E7600/E8600 to a Core 2 Quad in these systems; I would recommend wither the Q9505S or Q9550S - specifically the "S" on there as those are the 65W TDP versions of the 105W TDP Q9505 and Q9550.
Windows is only allowing 2 of the 4 cores of that Q6700 to run to fit within the TDP of the system (particularly by regulating how much power the CPU can draw), and MacOS is panicking as it doesn't know how to handle the 105W the Q6700 is asking for on a 65W system.
Hello,
I'd like to upgrade the Core 2 Duo 3.06 CPU of my iMac 10,1 21.5". I already done the same operation in a white Core Duo iMac, being able to install the unsupported OS X 10.7. I'd like to do the same on the 10,1 but what CPU can I install? It seems that the i3, i5 or i7 are phisically different, am I right? And the user Tim report in being unable to make it work with a Core 2 Quad. So... what are the possibilities? Thanks!
