Introducción
Replace your broken optical drive to keep those disks spinning.
Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
  • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
  • Loosen the two Phillips screws securing the access door to your iMac.
  • These screws are captive in the access door.
Agregar Comentario
Remove the access door from your iMac.
  • Remove the access door from your iMac.
Agregar Comentario
Remove the three T8 Torx screws securing the front bezel to the rear panel.
  • Remove the three T8 Torx screws securing the front bezel to the rear panel.
Agregar Comentario
Orient the iMac face-up, on its backside. Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
  • Orient the iMac face-up, on its backside.
  • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
Agregar Comentario
While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
  • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
Agregar Comentario
Re-orient your iMac so it sits upright on the stand. Insert a plastic card up into the corner of the air vent slot at the top of the rear case. Push the card toward the top of the iMac to release the front bezel latch.
  • Re-orient your iMac so it sits upright on the stand.
  • Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
  • Push the card toward the top of the iMac to release the front bezel latch.
  • Pull the front bezel away from the rear case.
  • Repeat this process for the other side of the front bezel.
  • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
  • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Using a strongish magnet will grab and release the latches.
darkstar448 - Contestar
Quote from darkstar448:
Are you sure it's safe to do this? How close is the hard drive, won't magnets interfere with it?
Sarah - Contestar
It's almost certainly fine. Modern hard drives are very resistant to magnetic fields.
zschroeder6212 -
Lay your iMac stand-side down on a table.
  • Lay your iMac stand-side down on a table.
  • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
  • Lay the front bezel above the rest of the iMac.
Agregar Comentario
If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
  • If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
Agregar Comentario
Disconnect both the camera and microphone cables. Disconnect both the camera and microphone cables.
  • Disconnect both the camera and microphone cables.
Agregar Comentario
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
  • Peel back the aluminum EMI shield up off the lower three edges of the rear case.
  • It is not necessary to peel the EMI shield off the display.
  • We found it helpful to tape the EMI shield up against the display to keep it out of the way.
Agregar Comentario
Remove the two 5 mm T6 Torx screws securing the display data cable to the logic board. Using its attached black tab, pull the display data cable connector up off the logic board.
  • Remove the two 5 mm T6 Torx screws securing the display data cable to the logic board.
  • Using its attached black tab, pull the display data cable connector up off the logic board.
Agregar Comentario
Pull the inverter cable connector up off its socket on the logic board.
  • Pull the inverter cable connector up off its socket on the logic board.
Agregar Comentario
Peel back the aluminum EMI tape from the two vertical edges of the display.
  • Peel back the aluminum EMI tape from the two vertical edges of the display.
  • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
Agregar Comentario
Remove the four recessed coarse-thread 7.5 mm T10 Torx screws securing the display to the rear case. These screws are recessed, so a thin screwdriver such as this is essential for removal. Bit drivers tend to be too short for this application.
  • Remove the four recessed coarse-thread 7.5 mm T10 Torx screws securing the display to the rear case.
  • These screws are recessed, so a thin screwdriver such as this is essential for removal. Bit drivers tend to be too short for this application.
No problem taking those screws off, HUGE problem trying to put them back in. Reassembling this step is a lot more complicated. Those 4 screws are impossible to reinstall if you don't have a magnetized screwdriver, which I don't.
javier - Contestar
I used some 'chapstik' on my t10 driver and it held the screws long enough to insert them.
aquarianknows -
Quote from javier:
Since I could not get a hold on a nice magnetized T10, I inverted the whole unit and worked upside down to avoid lost screws inside an iMac.
javier - Contestar
Quote from javier:
Great, now my problem is to find a new cable that connects the panel to LB.
I'm from Italy and nobody has got it .
Please help me
Thanks for all
Carlo
Lars - Contestar
I found a group of wires not mentioned on the instructions along the underside of the display at the right. They were connected to something at the right bottom of the display near the white plastic piece. I am unable to raise the display more than a couple of inches at this side of it and am wondering what do do.
modorange - Contestar
The group of wires on the right side of the display is the inverter. Seems like a few steps were omitted, so I'll try to fill in the gaps. Use the T10 to remove the right speaker. It's the big white plastic squarish thing on the bottom right side of the iMac. It pulls stright up and you can either disconnect it or just leave it hanging. This should release the inverter cable from hanging up the right side of the display (it did for me, even disconnecting the inverter didn't help as the cable was under the speaker, the inverter doesn't need to be disconnected but it might be helpful to disentangle things and it's an easy one to take apart). The other step missing is to remove the perforated tape at the top of the LCD from the LCD, otherwise you can't really remove it. I found a spudger helpful for this task.
I know it's a couple years since the OP posted, but hope this helps someone.
Cheers
Jeff Kamis
maccentric -
I've found that 'coating' the tip of the screwdriver with glue from a glue-stick will help to keep the screws from coming off of a non-magnetized driver.
Henry in StL - Contestar
Lift the display from its lower edge and pull it toward yourself to peel it off the EMI shield attached to its top edge.
  • Lift the display from its lower edge and pull it toward yourself to peel it off the EMI shield attached to its top edge.
  • Be mindful of any cables that may get caught during removal.
Agregar Comentario
Remove the T10 Torx screw securing the optical drive flex cable mounting bracket to the logic board. Remove the flex cable mounting bracket.
  • Remove the T10 Torx screw securing the optical drive flex cable mounting bracket to the logic board.
  • Remove the flex cable mounting bracket.
Agregar Comentario
Lift the optical drive flex cable connector straight up off the logic board.
  • Lift the optical drive flex cable connector straight up off the logic board.
  • This ribbon cable is thin and easily torn. Use caution.
Agregar Comentario
Move the SATA data cable away from the edge of the optical drive.
  • Move the SATA data cable away from the edge of the optical drive.
Agregar Comentario
Disconnect the optical drive thermal sensor.
  • Disconnect the optical drive thermal sensor.
Alternatively unstick the sensor from the drive, and leave it connected to the cable.
Trevor Hayes - Contestar
Apple's "engineers" didn't learn much about deflection and material stiffness when they went to "college", so this optical drive is particularly difficult to remove because the bracket flexes too much. The next few steps require some patience and a good amount of force. Insert the flat end of a spudger into the gap between the optical drive and its bracket until it contacts the chassis.
  • Apple's "engineers" didn't learn much about deflection and material stiffness when they went to "college", so this optical drive is particularly difficult to remove because the bracket flexes too much. The next few steps require some patience and a good amount of force.
  • Insert the flat end of a spudger into the gap between the optical drive and its bracket until it contacts the chassis.
  • Grab the spudger as close to the surface of the optical drive as you can, then depress the release tab with your thumb while pulling toward yourself.
  • The wedge shape of the spudger may cause it to slip out of the gap toward yourself. Be sure to press the spudger in toward the rear case while squeezing the release tab.
Agregar Comentario
Remove the two T10 Torx screws from the side of the optical drive.
  • Remove the two T10 Torx screws from the side of the optical drive.
  • It's a good idea to lay your iMac flat on a table before removing these screws to avoid them falling behind the logic board.
Removal of these screws can wait until the entire bracket assembly is out of the chassis. Remove the screws when you remove the bracket from the drive, step 23.
Use the flat end of a spudger to press the bottom edge of the lower optical drive bracket release tab toward the lower edge of the iMac.
  • Use the flat end of a spudger to press the bottom edge of the lower optical drive bracket release tab toward the lower edge of the iMac.
  • The optical drive should now be free from the rear case.
  • Maneuver the optical drive out of the rear case, minding the two plastic pins molded into the rear case near the open end of the optical drive that can break off.
Agregar Comentario
Remove the two T10 Torx screws from the side of your optical drive.
  • Remove the two T10 Torx screws from the side of your optical drive.
Agregar Comentario
Push the two optical drive bracket tabs out of their slots in the top of the optical drive. Push the two optical drive bracket tabs out of their slots in the top of the optical drive.
  • Push the two optical drive bracket tabs out of their slots in the top of the optical drive.
Agregar Comentario
Using the tip of a spudger, press the optical drive bracket tab out of its slot on the side of the optical drive.
  • Using the tip of a spudger, press the optical drive bracket tab out of its slot on the side of the optical drive.
Agregar Comentario
Use the tip of a spudger to push the optical drive bracket tabs out of their slots on the bottom of the optical drive. Use the tip of a spudger to push the optical drive bracket tabs out of their slots on the bottom of the optical drive.
  • Use the tip of a spudger to push the optical drive bracket tabs out of their slots on the bottom of the optical drive.
Agregar Comentario
Pull the optical drive bracket toward the open end of the optical drive to free it from the optical drive. Set the bracket aside.
  • Pull the optical drive bracket toward the open end of the optical drive to free it from the optical drive.
  • Set the bracket aside.
Agregar Comentario
Remove the two T6 Torx screws securing the optical drive flex cable to the optical drive.
  • Remove the two T6 Torx screws securing the optical drive flex cable to the optical drive.
Agregar Comentario
Insert the flat end of a spudger into the gap between the optical drive flex cable connector and the optical drive. Twist the spudger to separate the connector from the optical drive.
  • Insert the flat end of a spudger into the gap between the optical drive flex cable connector and the optical drive.
  • Twist the spudger to separate the connector from the optical drive.
  • Repeat this process for both sides of the connector.
Agregar Comentario
Pull the optical drive flex cable connector away from the optical drive.
  • Pull the optical drive flex cable connector away from the optical drive.
Agregar Comentario
Use a spudger to pry the optical drive thermal sensor off the optical drive.
  • Use a spudger to pry the optical drive thermal sensor off the optical drive.
  • Don't forget to transfer this to your new drive.
Agregar Comentario
Use the flat end of a spudger to remove the small piece of EMI foam from the underside of the optical drive.
  • Use the flat end of a spudger to remove the small piece of EMI foam from the underside of the optical drive.
  • Your optical drive is now completely stripped. If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
Agregar Comentario
Conclusión
7 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 6
Todo El Tiempo: 10,854
