Introducción
The ins and outs of replacing your IR board.
Qué necesitas
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Herramienta utilizada en este paso:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
