Introducción
Trip over your power cord? Use this guide to replace your AC power inlet.
Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
  • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
  • Loosen the two Phillips screws securing the access door to your iMac.
  • These screws are captive in the access door.
Agregar Comentario
Remove the access door from your iMac.
  • Remove the access door from your iMac.
Agregar Comentario
Remove the three T8 Torx screws securing the front bezel to the rear panel.
  • Remove the three T8 Torx screws securing the front bezel to the rear panel.
Agregar Comentario
Orient the iMac face-up, on its backside. Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
  • Orient the iMac face-up, on its backside.
  • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
Agregar Comentario
While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
  • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
Agregar Comentario
Re-orient your iMac so it sits upright on the stand. Insert a plastic card up into the corner of the air vent slot at the top of the rear case. Push the card toward the top of the iMac to release the front bezel latch.
  • Re-orient your iMac so it sits upright on the stand.
  • Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
  • Push the card toward the top of the iMac to release the front bezel latch.
  • Pull the front bezel away from the rear case.
  • Repeat this process for the other side of the front bezel.
  • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
  • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Using a strongish magnet will grab and release the latches.
darkstar448 - Contestar
Quote from darkstar448:
Are you sure it's safe to do this? How close is the hard drive, won't magnets interfere with it?
Sarah - Contestar
It's almost certainly fine. Modern hard drives are very resistant to magnetic fields.
zschroeder6212 -
Lay your iMac stand-side down on a table.
  • Lay your iMac stand-side down on a table.
  • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
  • Lay the front bezel above the rest of the iMac.
Agregar Comentario
If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
  • If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
Agregar Comentario
Disconnect both the camera and microphone cables. Disconnect both the camera and microphone cables.
  • Disconnect both the camera and microphone cables.
Agregar Comentario
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
  • Peel back the aluminum EMI shield up off the lower three edges of the rear case.
  • It is not necessary to peel the EMI shield off the display.
  • We found it helpful to tape the EMI shield up against the display to keep it out of the way.
Agregar Comentario
Remove the two 5 mm T6 Torx screws securing the display data cable to the logic board. Using its attached black tab, pull the display data cable connector up off the logic board.
  • Remove the two 5 mm T6 Torx screws securing the display data cable to the logic board.
  • Using its attached black tab, pull the display data cable connector up off the logic board.
Agregar Comentario
Pull the inverter cable connector up off its socket on the logic board.
  • Pull the inverter cable connector up off its socket on the logic board.
Agregar Comentario
Peel back the aluminum EMI tape from the two vertical edges of the display.
  • Peel back the aluminum EMI tape from the two vertical edges of the display.
  • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
Agregar Comentario
Remove the four recessed coarse-thread 7.5 mm T10 Torx screws securing the display to the rear case. These screws are recessed, so a thin screwdriver such as this is essential for removal. Bit drivers tend to be too short for this application.
  • Remove the four recessed coarse-thread 7.5 mm T10 Torx screws securing the display to the rear case.
  • These screws are recessed, so a thin screwdriver such as this is essential for removal. Bit drivers tend to be too short for this application.
No problem taking those screws off, HUGE problem trying to put them back in. Reassembling this step is a lot more complicated. Those 4 screws are impossible to reinstall if you don't have a magnetized screwdriver, which I don't.
javier - Contestar
I used some 'chapstik' on my t10 driver and it held the screws long enough to insert them.
aquarianknows -
Quote from javier:
Since I could not get a hold on a nice magnetized T10, I inverted the whole unit and worked upside down to avoid lost screws inside an iMac.
javier - Contestar
Quote from javier:
Great, now my problem is to find a new cable that connects the panel to LB.
I'm from Italy and nobody has got it .
Please help me
Thanks for all
Carlo
Lars - Contestar
I found a group of wires not mentioned on the instructions along the underside of the display at the right. They were connected to something at the right bottom of the display near the white plastic piece. I am unable to raise the display more than a couple of inches at this side of it and am wondering what do do.
modorange - Contestar
The group of wires on the right side of the display is the inverter. Seems like a few steps were omitted, so I'll try to fill in the gaps. Use the T10 to remove the right speaker. It's the big white plastic squarish thing on the bottom right side of the iMac. It pulls stright up and you can either disconnect it or just leave it hanging. This should release the inverter cable from hanging up the right side of the display (it did for me, even disconnecting the inverter didn't help as the cable was under the speaker, the inverter doesn't need to be disconnected but it might be helpful to disentangle things and it's an easy one to take apart). The other step missing is to remove the perforated tape at the top of the LCD from the LCD, otherwise you can't really remove it. I found a spudger helpful for this task.
I know it's a couple years since the OP posted, but hope this helps someone.
Cheers
Jeff Kamis
maccentric -
I've found that 'coating' the tip of the screwdriver with glue from a glue-stick will help to keep the screws from coming off of a non-magnetized driver.
Henry in StL - Contestar
Lift the display from its lower edge and pull it toward yourself to peel it off the EMI shield attached to its top edge.
  • Lift the display from its lower edge and pull it toward yourself to peel it off the EMI shield attached to its top edge.
  • Be mindful of any cables that may get caught during removal.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board. The IR board and cable finger are now free from the logic board and may fall.
  • Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board.
  • The IR board and cable finger are now free from the logic board and may fall.
  • Remove the IR cable finger and move the IR board, with cable still attached, out of the way.
Agregar Comentario
Remove the single 30 mm T10 Torx screw securing the left speaker to the rear case. Pull the left speaker out of the rear case.
  • Remove the single 30 mm T10 Torx screw securing the left speaker to the rear case.
  • Pull the left speaker out of the rear case.
Agregar Comentario
De-route the left speaker cable along its path across the logic board.
  • De-route the left speaker cable along its path across the logic board.
Agregar Comentario
Remove the single 17 mm T10 Torx screw securing the right speaker to the logic board. Lift the right speaker out of the rear case and move it out of the way.
  • Remove the single 17 mm T10 Torx screw securing the right speaker to the logic board.
  • Lift the right speaker out of the rear case and move it out of the way.
  • Both speakers are still attached to the logic board.
Agregar Comentario
If necessary, lift the IR board cable to free the left speaker cable pinned beneath. Pull the speaker connector toward the top edge of your iMac to disconnect it from the logic board.
  • If necessary, lift the IR board cable to free the left speaker cable pinned beneath.
  • Pull the speaker connector toward the top edge of your iMac to disconnect it from the logic board.
Agregar Comentario
Disconnect the CPU fan connector from the logic board by pulling it straight up from its socket. Disconnect the CPU fan connector from the logic board by pulling it straight up from its socket.
  • Disconnect the CPU fan connector from the logic board by pulling it straight up from its socket.
Agregar Comentario
Gently lift the CPU fan out of the rear case.
  • Gently lift the CPU fan out of the rear case.
Agregar Comentario
Disconnect the following connectors from the logic board by pulling them straight up from their sockets.:
  • Disconnect the following connectors from the logic board by pulling them straight up from their sockets.:
    • Ambient light sensor cable.
    • Power cable.
Agregar Comentario
  • Disconnect the hard drive data cable connector from the logic board by pulling it straight up from its socket.
  • The SATA connector on most iMacs tends to stick in its socket on the logic board. If you are having trouble disconnecting the SATA cable, insert a metal spudger or any other thin tool into the gap between the SATA connector and its socket and twist the spudger's shaft to safely separate the two pieces.
Agregar Comentario
De-route the IR sensor cable from behind the AirPort Express card and set it aside.
  • De-route the IR sensor cable from behind the AirPort Express card and set it aside.
Agregar Comentario
Remove two 5 mm T6 Torx screws securing the AirPort/Bluetooth board to the logic board. Lift the AirPort/Bluetooth board up from its left edge to separate it from its socket on the logic board.
  • Remove two 5 mm T6 Torx screws securing the AirPort/Bluetooth board to the logic board.
  • Lift the AirPort/Bluetooth board up from its left edge to separate it from its socket on the logic board.
  • Lift the AirPort/Bluetooth board from its left edge only. Trying to lift from its right edge may break the connector off the logic board.
Agregar Comentario
Use the flat end of a spudger to pry both antenna cables up off the AirPort/Bluetooth board. This step need not be done.  Simply lay the card over the side.
  • Use the flat end of a spudger to pry both antenna cables up off the AirPort/Bluetooth board.
  • This step need not be done. Simply lay the card over the side.
Agregar Comentario
Disconnect the camera board cable connector from the logic board by pulling it straight away from its socket.
  • Disconnect the camera board cable connector from the logic board by pulling it straight away from its socket.
Agregar Comentario
Disconnect the optical drive fan cable connector from the logic board by pulling it straight away from its socket.
  • Disconnect the optical drive fan cable connector from the logic board by pulling it straight away from its socket.
Agregar Comentario
Remove the 7 mm T10 Torx screw securing the optical drive flex cable mounting bracket to the logic board. Remove the flex cable mounting bracket.
  • Remove the 7 mm T10 Torx screw securing the optical drive flex cable mounting bracket to the logic board.
  • Remove the flex cable mounting bracket.
Agregar Comentario
Disconnect the optical drive flex cable from the logic board by pulling it straight up from its socket.
  • Disconnect the optical drive flex cable from the logic board by pulling it straight up from its socket.
Agregar Comentario
De-route the hard drive data cable and tuck it under the optical drive to prevent the cable from interfering with future steps.
  • De-route the hard drive data cable and tuck it under the optical drive to prevent the cable from interfering with future steps.
Agregar Comentario
Disconnect the hard drive fan connector from the logic board by pulling it straight away from its socket.
  • Disconnect the hard drive fan connector from the logic board by pulling it straight away from its socket.
Agregar Comentario
Use the tip of a spudger to lift the hard drive and optical drive thermal sensor cables for clearance. Disconnect the optical drive temperature sensor connector from the logic board by pulling it straight away from its socket.
  • Use the tip of a spudger to lift the hard drive and optical drive thermal sensor cables for clearance.
  • Disconnect the optical drive temperature sensor connector from the logic board by pulling it straight away from its socket.
Agregar Comentario
Disconnect the hard drive temperature sensor connector from the logic board by pulling it straight away from its socket.
  • Disconnect the hard drive temperature sensor connector from the logic board by pulling it straight away from its socket.
Agregar Comentario
Remove the following screws securing the logic board to the rear case:
  • Remove the following screws securing the logic board to the rear case:
    • Four fine threaded 7 mm T10 Torx screws.
    • Three coarse threaded 7 mm T10 Torx screws.
Agregar Comentario
Push the two RAM arms protruding from the access door inward and set them on the lower edge of the rear case to prevent them from getting caught when removing the logic board. Push the two RAM arms protruding from the access door inward and set them on the lower edge of the rear case to prevent them from getting caught when removing the logic board.
  • Push the two RAM arms protruding from the access door inward and set them on the lower edge of the rear case to prevent them from getting caught when removing the logic board.
Agregar Comentario
Grab the logic board and pull it toward yourself slightly to separate the jacks from the rear case. Rotate the top of the logic board toward yourself slightly to gain access to the DC power cable connector.
  • Grab the logic board and pull it toward yourself slightly to separate the jacks from the rear case.
  • Rotate the top of the logic board toward yourself slightly to gain access to the DC power cable connector.
  • Do not completely remove the logic board as the DC power cable connector is still connected to the underside of the board.
Agregar Comentario
While grasping the logic board with one hand, disconnect the DC power cable connector from the logic board by pulling it straight away from its socket.
  • While grasping the logic board with one hand, disconnect the DC power cable connector from the logic board by pulling it straight away from its socket.
  • It may be helpful to wiggle the connector while pulling it.
What is the capacitor list for the board as mine is missing to capacitors
bear250sxf - Contestar
Lift the hard drive fan off the plastic posts protruding from the rear case.
  • Lift the hard drive fan off the plastic posts protruding from the rear case.
  • If necessary, de-route the cables from under the chassis.
Agregar Comentario
Use a pair of tweezers to pull the AC-in cable out from underneath the chassis. Use a pair of tweezers to pull the AC-in cable out from underneath the chassis.
  • Use a pair of tweezers to pull the AC-in cable out from underneath the chassis.
Agregar Comentario
Disconnect the AC-in cable connector by depressing the lock mechanism while pulling the connector away from its socket.
  • Disconnect the AC-in cable connector by depressing the lock mechanism while pulling the connector away from its socket.
Agregar Comentario
Use a spudger to peel back the three pieces of EMI tape covering the AC power inlet.
  • Use a spudger to peel back the three pieces of EMI tape covering the AC power inlet.
  • The top and bottom pieces are easy to peel back, but the side piece is easily torn. Be patient while removing the EMI tape.
Agregar Comentario
Remove the following screws securing the AC power inlet to the rear case:
  • Remove the following screws securing the AC power inlet to the rear case:
    • Three T10 Torx screws
    • One T10 Torx screw securing the ground cable.
Agregar Comentario
De-route the AC-in cable connector from under the chassis and remove the AC power inlet from your iMac.
  • De-route the AC-in cable connector from under the chassis and remove the AC power inlet from your iMac.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 6
Todo El Tiempo: 10,160
